1Back to top Go down   project madness Empty project madness on Tue Apr 17, 2018 10:37 am
EnJCoop
EnJCoop
project madness Img_0515
project madness Img_0517
project madness Img_0516Hi All, I did say I would post some stuff, so here's some of the 'bike'...
I have made a start... Been working on the wiring harness and fixing up the tank and have located parts and what's missing. Am going to obtain the Reg document (V5) and start to put things back together again.
I'm gonna need stuff like injectors, fuel pump, battery, some relays, exhaust etc etc... so it could take A WHILE!!! Engine is not seized at least. it turned with a spanner on the cam shaft. Oh will need to refit valve shims too and the oil/coolant pump which looks in reasonably good shape.
And there's no seat or headlight or indicators... But cliches were not made in a day and all that and I am KEEN to see what I can make of this, though am not thinking Cafe racer here. Someone else might if I sell it once it's in better shape...
2Back to top Go down   project madness Empty Fuel injector plastic tip on Thu Apr 19, 2018 6:40 pm
EnJCoop
EnJCoop
Hi!
Does anyone know if the plastic fitting on the cylinder end of the fuel injector can be replaced?
I have four injectors and one is missing this part...
3Back to top Go down   project madness Empty Fuel injectors on Thu Apr 19, 2018 6:45 pm
EnJCoop
EnJCoop
4Back to top Go down   project madness Empty Re: project madness on Fri Apr 20, 2018 3:20 am
I think you found it neil
I have a few pintle caps here you could use , just send me an address and ill send you one
but the big question is ....where did the other pintle cap get to ?  hopefully its not sitting inside the inlet area of the head ???
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%Oproject madness Au-log10
5Back to top Go down   project madness Empty Pintle cap on Fri Apr 20, 2018 7:12 pm
EnJCoop
EnJCoop
@charlie99 wrote:I think you found it neil
Thanks! Well, it broke a while back when I was working on my previous K100 project... I guess it had become brittle or something.
If you dont mind sending one (which is very kind of you) it's
Neal Cooper
34 Dornton Road, Balham, London SW12 9ND UK
bounce
6Back to top Go down   project madness Empty Re: project madness on Sat Apr 21, 2018 7:17 am
will do
7Back to top Go down   project madness Empty Re: project madness on Sat Apr 21, 2018 7:46 am
Oh no! I used to live just round the corner from him! (Cavendish Road) Very Happy
8Back to top Go down   project madness Empty Pintle cap on Tue Apr 24, 2018 4:22 am
EnJCoop
EnJCoop
@charlie99 wrote:will do
Thank you kindly!
9Back to top Go down   project madness Empty Re: project madness on Thu Apr 26, 2018 3:23 am
sorry for delay but sent today
