1Back to top Go down   Don't know what to do😱 Empty Don't know what to do😱 on Mon Apr 23, 2018 4:41 am
dakelvinator
dakelvinator
Hi just wanted peoples opinions?
I have a 1991 k100 but it probably needs a fair but spending on it it needs rear disc, clutch oil seal, water pump, cables, a good scrub!, It has 97k on it and I still use it regularly i did 200 miles on Saturday it uses oil (but i put that down to the clutch seal, it was near the top of the sight glass and now is near the bottom after 200miles)
So my question is do I repair it or go for a new bike something like an r1100 rt for under 3k? I would try to do the work myself however the clutch seal frightens me! Thanks k
2Back to top Go down   Don't know what to do😱 Empty Re: Don't know what to do😱 on Mon Apr 23, 2018 5:06 am
Would you rather ride or wrench? Very Happy
3Back to top Go down   Don't know what to do😱 Empty Re: Don't know what to do😱 on Mon Apr 23, 2018 5:26 am
You buy an R1100 you will have similar things to fix. Just hop in there and do it. It is not that difficult. If you would fix the front wheel bearings on your car you are quite capable of doing any work required. The sooner you fix it the sooner you'll be out there picking the bugs out of your teeth.
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
4Back to top Go down   Don't know what to do😱 Empty Re: Don't know what to do😱 on Mon Apr 23, 2018 5:45 am
dakelvinator
dakelvinator
Haha yes bugs in my teeth a bit of protein! Love riding it don't mind wrench work just struggle for time! It's not urgent as it's still going strong so I could do it in stages, I think before i start anything I will do a compression test just to make sure it's worth the effort!
5Back to top Go down   Don't know what to do😱 Empty Re: Don't know what to do😱 on Mon Apr 23, 2018 7:09 am
Just start a program of maintenance and keep at it and soon you'll have a bike that's getting better and better to ride and needs less work.
6Back to top Go down   Don't know what to do😱 Empty Re: Don't know what to do😱 on Mon Apr 23, 2018 7:36 am
Check out the oil consumption before going at anything. The clutch seal shouldn't be using that much, otherwise the clutch would be toast long ago. But that seal issue will potentially be on any BMW bike, K or R bike alike. Its not so difficult to do especially if some forum member was enticed over your way witha beer or two. 4v engines apparently use a drop of oil anyway. So I would do an accurate measure. I got my K1100 and check the oil a lot. A bit dismayed first time to find a drop then looked at the clock and it was 1000 miles since the previous weeks check. Took about 250ml which is like a litre in 4,000 miles of mostly motorway driving. I didn't see anything wrong in that. I still keep a regular eye on it but its now fine.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now91,850 miles
1983 K100RS 0011175 Fricka 29,495 miles Damn K Pox
7Back to top Go down   Don't know what to do😱 Empty Re: Don't know what to do😱 on Mon Apr 23, 2018 7:58 am
I have a 4 valve K100RS of unknown mileage. It uses about a quart of oil every 800-900 miles which is a lot more than my other bricks. It starts readily, idles smoothly and runs like a freight train. For the cost of a ring job I can buy enough Rotella T6 synthetic to ride at least another 40,000+ miles.
8Back to top Go down   Don't know what to do😱 Empty Re: Don't know what to do😱 on Mon Apr 23, 2018 8:23 am
dakelvinator
dakelvinator
Snap my k100 is like that starts and goes real well! It's always used oil so I'll just keep an eye on it, it's one of those things undoubtedly i would miss it if I sold it but then my sensible side panics as it is 27 years old! Well if anyone has done this job before and fancy`s giving me a hand in exchange for beer am near Burnley Manchester uk! Haha 😀
9Back to top Go down   Don't know what to do😱 Empty Re: Don't know what to do😱 on Mon Apr 23, 2018 8:42 am
The BMW spec for allowable oil consumption borders on insane. From page 00-30 of the BMW K75/K100 Repair Manual:
"Maximum permissible oil consumption rate: 0.151 l per 100km." affraid
Which works out to 2.55 quarts every 1,000 miles or 1.51 liters every 1,000 km.
10Back to top Go down   Don't know what to do😱 Empty Re: Don't know what to do😱 on Mon Apr 23, 2018 8:55 am
dakelvinator
dakelvinator
Wow I feel it's almost normal! That's some tolerance
11Back to top Go down   Don't know what to do😱 Empty Re: Don't know what to do😱 on Mon Apr 23, 2018 11:11 am
In the olden days at Beemer rallies we could always count on K bikes to clear out the mozzies when they started up, such was the cloud bank emitted. Of course, that was the early bikes, but left on the side stand, most, not all, will still remind you they have oil in them.
1987 K100RS, '89 K100 w/K1100RS engine, '93 Framed K11/K12 engine 'Big Block', '96 K1100RS, '09 K1300GT, '07 K1200R, '95 R100 Mystic & '77 R75/7.
12Back to top Go down   Don't know what to do😱 Empty Re: Don't know what to do😱 on Mon Apr 23, 2018 11:23 am
dakelvinator
dakelvinator
Good way to clear the mozzys haha!
