1Back to top Go down   K75 Injectors not firing Empty K75 Injectors not firing Sun May 06, 2018 9:36 pm
Rockman
I had a bit of a go at getting the K75 going on sunday. New fuel pump is installed and working, and it has spark, but the injectors are not firing, so no go. Its all 3 that dont squirt fuel, so the problem is somewhere in the circuitry that controls them. So where do I look?
2Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Sun May 06, 2018 9:51 pm
Use the old screwdriver handle to your ear trick and listen for them clicking, this will make sure that they are opening or at least getting the signal.
If you have fuel pressure and can hear the click then pull the injectors and clean them.
If there is no click then there is a good chance they are stuck closed or the signal is not getting through. Make sure the multi pin plug on the ecu is pushed home and the contacts are clean.
3Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Mon May 07, 2018 12:36 am
Rockman
RicK G wrote:Use the old screwdriver handle to your ear trick and listen for them clicking, this will make sure that they are opening or at least getting the signal.
I actually pulled them out to check. Absolutely nothing on all 3 so I'm thinking no signal as I'd expect at least 1 to show signs of life if they were stuck. Is there a relay in the box under the tank as well as the ecu
4Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Mon May 07, 2018 12:57 am
This is where he relays are. If you get Bert's flow chart it will guide you through the process.
K75 Injectors not firing Abs_k110
5Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Mon May 07, 2018 2:07 am
phil you could stick your multimeter across one of the injector electrical connections and ground and measure if you have 12 volts on one of the terminals )key on )  I believe that the under seat ficu grounds the injectors whilst operating ...that might tell you if there is a volt supply issue further back into the electrics before much else
we know that the relays can sometimes be intermittent after all these years
good luck
6Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Mon May 07, 2018 5:16 am
charlie99 wrote:phil you could stick your multimeter across one of the injector electrical connections and ground and measure if you have 12 volts on one of the terminals )key on )
The starter button must be pushed or the engine must be running to make
the FI relay to operate and supplying 12V.
7Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Mon May 07, 2018 5:21 am
good point inge ...cheers
8Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Thu May 10, 2018 1:30 am
club_c
club_c
Rockman wrote:I had a bit of a go at getting the K75 going on sunday. New fuel pump is installed and working, and it has spark, but the injectors are not firing, so no go. Its all 3 that dont squirt fuel, so the problem is somewhere in the circuitry that controls them. So where do I look?
When I pulled down my first K100 I had the injectors out while I did the restoration.  The injectors actually sealed themselves up while they were out.  There was a varnish film on them that stayed wet while in the fuel rail, but once pulled out they sealed up and could not be saved.  It fired straight up once they were replaced.  I made a little test light from a red LED bulb to confirm power to the injectors.  I think crazyfrog may have pointed me in that direction.   I expect there is a page on it here somewhere...
1988 K100RS SE VIN 01477554
9Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Thu May 10, 2018 7:56 pm
Rockman
This might be the case so I'll have to test if I am getting power to them as Charlie suggested. The bikes been sitting dry for a fair while.
10Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Fri May 11, 2018 5:02 am
ive had some  great results from using white vinegar (as suggested by either .75 or laitch ...sorry cant remember ) recently
dump the injectors into a small bottle - jar  enough to cover the pintle area at least , 1/2 an inch deep  and let them soak overnight at least
havent tried the whole injector in the solution yet ...not sure its safe to do so , but my thinking is that it may loosen the sticky mass inside the injector holding the pintles ??
just a thought
11Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Fri May 11, 2018 7:54 am
Theres a 4-pin circular connector that joins the injector sub-harness to the main harness. This connector is similar to the fuel tank one, which gives many people grief. It's possible this connector is not mating properly and you won't get power to the injectors. Check and clean it.
12Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Fri May 11, 2018 8:06 am
K75 Injectors not firing 112350
13Back to top Go down   K75 Injectors not firing Empty Partial success Sun May 27, 2018 8:09 pm
Rockman
I tried Charlie's suggestion of white vinegar with partial success. So far 1 have managed to get 1 of the three going. The other 2 are still soaking in it (Mrs Marsh was it?). Failing that can anyone suggest a cheap source for new injectors?
Update: After searching the forum and getting thoroughly confused I have purchased a set of 3 for a 5 litre ford falcon off ebay. At $57 all up I'm not much out of pocket it they dont fit.
14Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Mon May 28, 2018 3:52 am
I seem to have a collection of non-functioning injectors as well, so would be interested to hear your results and if there are original ones to be had somewhere.
Sean
15Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Mon May 28, 2018 8:28 am
I have got 2 non firing injectors working by taping them onto a copper bar to knock the pintle valve open and then they have performed OK.  A couple of others that I freed up when rust was involved have worn and were running rich. There is no guarantee but what have you to lose.
I clean them using dishwasher detergent in an ultrasonic tub then final flush with carb cleaner while holding 9 volts on the coil which stops it overheating which is what happens when 12 volts is used.
16Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Mon May 28, 2018 8:31 am
Rockman wrote:I tried Charlie's suggestion of white vinegar with partial success. So far 1 have managed to get 1 of the three going. The other 2 are still soaking in it (Mrs Marsh was it?). Failing that can anyone suggest a cheap source for new injectors?
Update: After searching the forum and getting thoroughly confused I have purchased a set of 3 for a 5 litre ford falcon off eBay. At $57 all up I'm not much out of pocket it they don't fit.
The 5 litre ford uses the same Bosch injector as the K100/K75 so it should be OK
17Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Mon May 28, 2018 6:36 pm
A local workshop that cleans injectors told me they use lacquer thinners to clean theirs. I did give it ago in a Aldi sonic cleaner and it did eventually clean a couple of stubborn ones. However it didn't do much good with the lid on the cleaner, which softened to moldable condition. K75 Injectors not firing 44271 I now owe the Honorable Minister for Finance and Recreation a new jewelry cleaner. K75 Injectors not firing 167893 K75 Injectors not firing 161205
18Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Mon May 28, 2018 8:05 pm
Rockman
Saxon7 wrote:I seem to have a collection of non-functioning injectors as well, so would be interested to hear your results and if there are original ones to be had somewhere.
Sean
G'day Sean
I cancelled the first order as I had misread the ad, but now have a set of 8 coming for $170. If they are ok are you interested in going halves? (4 each, I'll have a spare)
19Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Mon May 28, 2018 8:45 pm
Yep that'll work. Let me know how it goes.
Sean
20Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Mon May 28, 2018 11:30 pm
MartinW wrote:A local workshop that cleans injectors told me they use lacquer thinners to clean theirs. I did give it ago in a Aldi sonic cleaner and it did eventually clean a couple of stubborn ones. However it didn't do much good with the lid on the cleaner, which softened to moldable condition. K75 Injectors not firing 44271 I know owe the Honorable Minister for Finance and Recreation a new jewelry cleaner. K75 Injectors not firing 167893 K75 Injectors not firing 161205
Sell all the jewelry and buy a big ultrasonic cleaner.
21Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Mon May 28, 2018 11:42 pm
Tesla13BMW
Tesla13BMW
I have a large ultrasonic for cleaning records in and there is no way on this world a filthy dirty injector is getting anywhere near it.
But, my turn table is worth as much as my K  What a Face
Brisbane, Australia.  '86 K100RS
22Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Thu May 31, 2018 8:16 pm
Rockman
New injectors showed up in the mail today, all 8 of them. Bosch 0280155844. I'll fit them tomorrow and see what happens Very Happy
23Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Thu May 31, 2018 9:23 pm
:like:There's a chance I'll be passing through Inverell on a loop from home to Glen on Sunday, ( if I manage to get  my uni stuff finished)
Will get in touch tomorrow evening to see if you're about.
Sean.
24Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Thu May 31, 2018 9:34 pm
Rockman
Saxon7 wrote::like:There's a chance I'll be passing through Inverell on a loop from home to Glen on Sunday, ( if I manage to get  my uni stuff finished)
Sean.
Yes do that. I'll bung these in the K75 tomorrow. In theory it should run straight away.
EDIT: And it did - purrs like a Kitten. Full service now and get it back on the road. I have about 3 fairing sets to choose from, and 4 seats, 3 screens etc so I'll have to sort through them and select which I want.
Last edited by Rockman on Sun Jun 03, 2018 9:28 pm; edited 1 time in total (Reason for editing : added stuff)
25Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Thu Jun 07, 2018 5:54 am
GF Wollongong
GF Wollongong
Probably a bit late now...
Search on youtube for DIY injector cleaning. Problem is that once cleaned, the flow rate might still be out unless measured.
Of course, you can buy injector service kits easily and cheaply enough.
One thing I do when "servicing" mine is to reverse flush the injector. Unless the filter is replaced on the top (use a self taping screw and pull it out) there will be debris / shite in it. A reverse flush blow it back out of the top.
Haven't worked out a good way to measure flow rate... some of you more able fabricators can work out a device that:
Uses a piece of circular wood (eg hole saw) attached to a drill on #1 speed / or drill press geared down
One the edge of the wood attach a piece of very thin metal sheet to create an eccentric edge
When spun around, the thin metal sheet creates an on / off switch for the circuit...
Circuit = 9V battery, wired to a fuel injector (alligator clips)
Top of the injector uses the tire valve, pressurised carby cleaner and straw (on youtube)
Cleaning continued accurately over say a minute and output / flow rate measured into a container.
A small piece of board could be used to secure all the bits and pieces
So at this stage of my reply, I looked on youtube and found:
https://www.youtube.com/watch?v=wF0zQCkbIr0
NB: I don't think injectors are meant to be on for too long
Note comment about using a digital scale to measure weight
I still have a bag of bits from Jaycar to mount a small motor to imitate the on off action of real life.
One day!!
GF
26Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Thu Jun 07, 2018 6:01 am
Sean.
good to hear mate
love to hear a ride report when you get it down the road
27Back to top Go down   K75 Injectors not firing Empty Re: K75 Injectors not firing Thu Jun 07, 2018 6:03 pm
In order to test injectors and flow rates you can get a injector tester off Ebay or Alibaba. https://www.ebay.com.au/itm/EM276-Injector-Tester-Fuel-Injector-4-Pluse-Modes-Tester-Fuel-System-Scan-Tool/112837522316?hash=item1a45a3f38c:g:rngAAOSwQbhak8mM The unit will pulse the injectors at various rates. I use this in conjunction with a 250ml graduated vessel.  Original home made tester worked but the commercial version was better.I also built a rig to pressurize the injectors using air from my compressor which can be adjusted to supply the correct pressure. Pictures are a guide the unit has changed slightly as lessons were learnt. Be very careful when testing injectors on the bike as if you are not extremely careful fires can result. KABOOM. Have a fire extinguisher.
K75 Injectors not firing 250_ml11 I
K75 Injectors not firing Fuel_i11
K75 Injectors not firing Fuel_i10
