1Back to top Go down   Wiring to fuel pump Empty Wiring to fuel pump Mon May 21, 2018 3:01 am
Rockman
The insulation on the wiring for my fuel pump has cracked in various places. It still works ok but needs replacing. The only question I have is what to replace it with. Is normal insulated wire fuel proof? or is there something better?
2Back to top Go down   Wiring to fuel pump Empty Re: Wiring to fuel pump Mon May 21, 2018 3:31 am
This subject shows now and then here, the conclusion earlier have been silicone insulated wire have the best resistance to fuel.
3Back to top Go down   Wiring to fuel pump Empty Re: Wiring to fuel pump Mon May 21, 2018 7:49 pm
Rockman
Inge K. wrote:This subject shows now and then here, the conclusion earlier have been silicone insulated wire have the best resistance to fuel.
Thanks Inge. Thats all I needed to know.
4Back to top Go down   Wiring to fuel pump Empty Re: Wiring to fuel pump Tue May 22, 2018 3:43 am
Sorry, after a further check it seems that I don't remember that good.
Nitrile, Teflon or Viton is a better material, silicone is not recommended.
The fuel hoses inside the tank is made of nitrile.
5Back to top Go down   Wiring to fuel pump Empty Re: Wiring to fuel pump Tue May 22, 2018 8:26 pm
Teflon is the best, and in my experience, a lot easier to find.
6Back to top Go down   Wiring to fuel pump Empty Re: Wiring to fuel pump Wed May 23, 2018 12:58 am
Rockman
Ok, teflon it is. Smile
