1Back to top Go down    Valve shims on Sun May 20, 2018 11:34 am
Neal Cooper
Neal Cooper
Hello to all,
I am not able to work on my 'bike' due to work commitments abroad at the moment...unfortunately.
Valve shims - I was endeavouring to put shims back in and even with the round ended bucket depressor and spacer it was very difficult as I didn't have the pointed pry tool with the ball on the end. When I get back I will have another go using something pointy...
Found a used fuel pump on ebay and have bought that.
I will need an exhaust system...
Is the final drive crown wheel bearing easy to get off or should I just try and get a second hand unit?
Found this post which is comprehensive and so will try to fix I think:http://www.k100-forum.com/t5697-how-to-check-and-replace-the-final-drive-crown-wheel-bearing-and-seal
Neal
2Back to top Go down    Re: Valve shims on Tue May 22, 2018 6:41 pm
Snod Blatter
Snod Blatter
@Neal Cooper wrote:Valve shims - I was endeavouring to put shims back in and even with the round ended bucket depressor and spacer it was very difficult as I didn't have the pointed pry tool with the ball on the end. When I get back I will have another go using something pointy...
For the shims I actually used a hypodermic needle and that was barely sharp enough, they are a right pain to get out!
The crown wheel bearing can be a nightmare, I had to take mine to a workshop to have it pressed off while the bloke attacked it with a blow torch. It is possible that some are tighter than others. I would heavily recommend checking the condition of the input splines and using that to help you decide what to do, if the splines are worn and the crown wheel bearing is goosed then I would view the unit as scrap and go find a better one. Beware there is a good chance you'll have to re-shim it too after fitting the new bearing, for extra faff points.
1989 K100RS SE ABS 8v VIN: 0149214
Others: 1.5 x Honda CBX250RS-E, '94 CB250, '95 TRX850, '16 Z250SL
3Back to top Go down    Re: Valve shims on Tue May 22, 2018 8:24 pm
Put a sharp point under the shim where the cutaway section is and a small magnet to grab the shim and after 30 years practice it's easy.
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
4Back to top Go down    Re: Valve shims on Wed May 23, 2018 7:12 pm
I haven't done this myself but have a look at this video of someone using compressed air to pop the shim out. Maybe that method can reduce the 30 year learning curve.
Here's the video
95 K1100LT 0232224; 90 K75 6427509; 87 R80G/S PD 6292136
5Back to top Go down    Re: Valve shims on Wed May 23, 2018 8:20 pm
Do they tell how oil sprays everywhere
6Back to top Go down    Re: Valve shims on Sat May 26, 2018 6:43 am
Neal Cooper
Neal Cooper
@RicK G wrote:Put a sharp point under the shim where the cutaway section is and a small magnet to grab the shim and after 30 years practice it's easy.
Yes, I remember the first time I did it on my first K100 and it was easier. I didn't have a decent sharp pointed implement this time and my rechargeable work light was low on juice... Then I got the special tool stuck behind the cam shaft because I was using it the wrong way round for the inlet valves (lift up for this side if I remember correctly, push down for exhaust ?). Then I started to lose patience which is never a good state of mind when working on a bike... Shocked
BUT when I get back to my garage I will sort this. Thanks all for your input.
7Back to top Go down    Re: Valve shims on Sat May 26, 2018 6:43 am
Neal Cooper
Neal Cooper
@Gaz wrote:I haven't done this myself but have a look at this video of someone using compressed air to pop the shim out. Maybe that method can reduce the 30 year learning curve.
Here's the video
Like it!
8Back to top Go down    Re: Valve shims on Sat May 26, 2018 6:47 am
Neal Cooper
Neal Cooper
Yes, and a new output bearing is 48 from Motorworks! Might not be worth it if the splines are in bad shape...
9Back to top Go down    Re: Valve shims on Sat May 26, 2018 7:33 am
If you have the bucket depressed and the shim not pinched, try using a slim, telescopic magnet 315USD. That's all I use for extraction and replacement.
The $3.30 version illustrated below is available in multicolors. Mine is chrome-colored; I just can't decide yet on a shade that harmonizes with lubricant yet expresses depth-of-feeling.
1995 K75T 68,000 miles
10Back to top Go down    Re: Valve shims on Sat May 26, 2018 5:42 pm
Neal Cooper
Neal Cooper
I have the very thing... with built in LED torch...I'm in business
11Back to top Go down    Re: Valve shims on Mon May 28, 2018 9:26 am
Snod Blatter
Snod Blatter
@Neal Cooper wrote:Yes, and a new output bearing is 48 from Motorworks! Might not be worth it if the splines are in bad shape...
Shims are about 15 each once you've paid for postage, and output seals are about 10 if you want to replace it. And you may well have to pay someone to get the bearing off, and if you don't have some angled feeler gauges or a dial guage and a steady stand then you may have to buy some tools to be able to shim it properly.. Nightmare really.
I'm not out to put you off, by all means have a go but beware it's not as easy as some people say!
12Back to top Go down    Re: Valve shims on Mon Jun 04, 2018 7:09 am
Neal Cooper
Neal Cooper
https://youtu.be/-1sM29zGxeo
Yes, things aren't necessarily easy...skill, knowledge and experience do definitely count... Laughing
