1Back to top Go down   How to remove Oetiker clips Empty How to remove Oetiker clips on Sun May 20, 2018 9:22 pm
nods
nods
I've seen the post on securing new clips, but how do you get the buggers off?
These are the ones securing the rubber manifold boot to the throttle body.
Thanks!
Chassis number0025951
Vehicle code0504
ModelK 100 RT 84 (0504 ( 0505 )
Body typeK 100 RT 84 (0504
Production date1985 / 01
Engine0514)
Transmission
Steering
CatalyzerNONE
2Back to top Go down   How to remove Oetiker clips Empty Re: How to remove Oetiker clips on Sun May 20, 2018 9:26 pm
Snip with big snippers.
3Back to top Go down   How to remove Oetiker clips Empty Re: How to remove Oetiker clips on Sun May 20, 2018 9:27 pm
Dremel cutting wheel.
You can also stick a small screwdriver in them and wiggle it around a bunch to loosen them.
4Back to top Go down   How to remove Oetiker clips Empty Re: How to remove Oetiker clips on Sun May 20, 2018 10:17 pm
nods
nods
Thanks a lot guys 👍
Sent from Topic'it App
Vehicle code0504
Engine0514)
Transmission
Steering
CatalyzerNONE
5Back to top Go down   How to remove Oetiker clips Empty Re: How to remove Oetiker clips on Mon May 21, 2018 1:23 am
Rockman
If you are a bit careful prising them off with a screwdriver they can be reused. I have used a pincer style cutters to crimp them up again without problems, although I expect there is a correct tool for the job.
6Back to top Go down   How to remove Oetiker clips Empty Re: How to remove Oetiker clips on Mon May 21, 2018 3:57 am
nods
nods
Thanks mate I'll give it a crack
Vehicle code0504
Engine0514)
Transmission
Steering
CatalyzerNONE
7Back to top Go down   How to remove Oetiker clips Empty Re: How to remove Oetiker clips on Mon May 21, 2018 6:21 am
Swap the clips for the fuel line clips off the R bikes. They are screw type ss worm drive and suitable for the application. You need 6 of them and position the screw heads where they are accessible without moving stuff. Even the ones on the fuel pressure regulator can be accessed with a long screwdriver if you do this. Everything is then reusable. If you still have original fuel lines on your K bike do this and also put new 40mm longer fuel hoses on and all s good.
Also works for the other large diameter connections to the air box. Just make sure heads do not interfere with throttle mechanism.
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
8Back to top Go down   How to remove Oetiker clips Empty Re: How to remove Oetiker clips on Mon May 21, 2018 6:46 pm
nods
nods
Thanks Olaf
Vehicle code0504
Engine0514)
Transmission
Steering
CatalyzerNONE
