1Back to top Go down    Towing my 84 k100 trike on Tue May 22, 2018 11:50 am
Gauntlett
Gauntlett
Desperate need to tow my trike 360 miles, is this ok given the type of gearbox we have, perhaps 100 miles at a time then run engine in neutral for a few minutes leave ten minutes and then continue need advise asap
2Back to top Go down    Re: Towing my 84 k100 trike on Tue May 22, 2018 12:06 pm
I am not sure that's legalunless it's on a towing dolly.
However rear wheel drive cars [manual, not auto] regularly get towed on a dolly without issues and we have car type drive train on the Ks.
Running engine in neutral won't do anything as there will be no drive into the transmission in neutral.
Trikes often fit on 3 bike trailers...
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now 87,050 miles
1983 K100RS 0011175 Fricka 29,000 miles Damn K Pox
3Back to top Go down    Re: Towing my 84 k100 trike on Tue May 22, 2018 12:20 pm
Gauntlett
Gauntlett
Special towing hitch for trikes fitted.I mentioned running the engine as it will rotate the input shaft rather than the output shaft whilst towing
4Back to top Go down    Re: Towing my 84 k100 trike on Tue May 22, 2018 12:59 pm
Gauntlett
Gauntlett
It's ok just had to loosen axle a bit propshaft now discovered
5Back to top Go down    Re: Towing my 84 k100 trike on Tue May 22, 2018 1:47 pm
Not sure what your rear gearing is but for a 2 wheeler I'd remove the drive shaft.
(Not be to taken as professional technical advice. Just employing some common sense.)
6Back to top Go down    Re: Towing my 84 k100 trike on Tue May 22, 2018 5:28 pm
+1 I'd go with removing the tail shaft it can't hurt.
7Back to top Go down    Re: Towing my 84 k100 trike on Thu May 24, 2018 4:16 pm
Why do you want to start your engine in neutral sometimes? That won't change anything to the gear lubrication.
Tow it as far as you want to, it will cause less stress to the transmission than if you ride it.
