1Back to top Go down   Which clutch plate Empty Which clutch plate on Sat May 26, 2018 2:32 am
nino
Hello everybody,
for me is time to change clutch plate. Bike has 192 tkm last time I did it at 130 tkm without changing other parts of the clutch except O ring on flywheel. In this moment no traces of oil in clutch area.
Motobins offers three options:
1. standard clutch plate
2. reinforced heat resistant plate
3. oil proof plate
Anybody on forum tried oil resistant plate?
2Back to top Go down   Which clutch plate Empty Re: Which clutch plate on Sat May 26, 2018 3:17 am
I have heard some negative reports from the oil resistant plate. I would just get a standard plate you got good service from the last plate.
3Back to top Go down   Which clutch plate Empty Re: Which clutch plate on Sat May 26, 2018 7:21 am
What Rick says. I got 147 tKm from the standard plate that I have just changed.
4Back to top Go down   Which clutch plate Empty Re: Which clutch plate on Sat May 26, 2018 7:34 am
my elcheapo Italian made version from the motobins chewed out the splines way too early … im sure I greased it properly
I would go for the standard version
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OWhich clutch plate Au-log10
5Back to top Go down   Which clutch plate Empty Re: Which clutch plate on Sat May 26, 2018 7:40 am
Standard, unless you're using the bike two-up when hauling gravel with a trailer.
1995 K75 73,000 miles
Which clutch plate Usa-lo10
6Back to top Go down   Which clutch plate Empty Re: Which clutch plate on Sat May 26, 2018 1:39 pm
nino
Thanks. Fastest delivery for TRW Lucas clutch plate. Anybody tried it?
7Back to top Go down   Which clutch plate Empty Re: Which clutch plate on Sat May 26, 2018 3:36 pm
No. Mine was a Sachs from Motorworks.
