1Back to top Go down   left hand switch - headlight dipper Empty left hand switch - headlight dipper on Sun Jun 03, 2018 9:23 pm
Rockman
I'm after a complete lhs switch block, or even just one with a working high/low beam switch. The one on my k75 has been butchered and an auxilliary dipper switch fitted to the handle bars. The plastic bit of the rocker switch looks ok.
2Back to top Go down   left hand switch - headlight dipper Empty Re: left hand switch - headlight dipper on Sun Jun 03, 2018 9:37 pm
I have a complete left switch block but it has the green rocker switch for an electric screen. It was on a K75. PM if you want it.
3Back to top Go down   left hand switch - headlight dipper Empty Re: left hand switch - headlight dipper on Tue Jun 05, 2018 9:30 am
Stumpy
Stumpy
@Rockman wrote:I'm after a complete lhs switch block, or even just one with a working high/low beam switch. The one on my k75 has been butchered and an auxilliary dipper switch fitted to the handle bars. The plastic bit of the rocker switch looks ok.
I have a similar problem on my K100 I have a yellow wire trailing across from the RHS to a toggle switch. I have now sourced both side switches, just need time to fit them.
4Back to top Go down   left hand switch - headlight dipper Empty Re: left hand switch - headlight dipper on Thu Jun 07, 2018 6:00 am
GF Wollongong
GF Wollongong
Rockman
Are you still after the LHS switch assembly?
I have one off a 1984 K100 RS.
It's intact. I assume it works.
Let me know
Guy
5Back to top Go down   left hand switch - headlight dipper Empty Re: left hand switch - headlight dipper on Thu Jun 07, 2018 8:17 pm
Rockman
@GF Wollongong wrote:Rockman
Let me know
Guy
Thanks Guy, but Rick G has come up trumps again.
Phil
