1Back to top Go down   engine suspension bolt spacer Empty engine suspension bolt spacer Mon Jul 09, 2018 3:43 pm
mister_anger
mister_anger
hello,
In the K100 parts manual I see a spacer between the frame and the engine suspension point at the left/front side.
The parts manual even shows different spacers in different thickness.
I didn't see that spacer when I dismantled my bike.
I could have missed it.
When I installed the frame back I saw a real small gap in between the frame and the enigne point but it closed when I tightened the bolt.
I am talking about less then 1 mm. Would this spacer be real important?
thx,M
2Back to top Go down   engine suspension bolt spacer Empty Re: engine suspension bolt spacer Mon Jul 09, 2018 3:55 pm
Yes, that spacer is really important. It needs to be in place otherwise the tracking of the motorcycle could be off, which is a dangerous situation. There are specific instructions in the OEM service manual for your year and model of K-bike for torquing up the frame and determining the correct size of that spacer.
3Back to top Go down   engine suspension bolt spacer Empty Re: engine suspension bolt spacer Mon Jul 09, 2018 5:02 pm
mister_anger
mister_anger
I have the Haynes manual but can't find any info on this spacer.
You say OEM service manual?
4Back to top Go down   engine suspension bolt spacer Empty Re: engine suspension bolt spacer Mon Jul 09, 2018 5:07 pm
mister_anger
mister_anger
checked again and I found the needed info, thanks
5Back to top Go down   engine suspension bolt spacer Empty Re: engine suspension bolt spacer Mon Jul 09, 2018 5:55 pm
The spacer also affects vibration damping. It is very important to get those shims right.
