Lowood Motorcycle Swap 21st and 22nd July. Charlie if your going to the July Laidley swap meet, don't. You will be too early and it will be extremely boring waiting till October. If you want something to do in July go to the Lowood swap in Lindemans rd Lowood. Who's going and I'll definitely be bricking it at this stage.
doh...!!!   yes the flyer did say Lowood ….  and I thought Laidley ...omg
im thinking this will also be a historic meet ….but none the less ...a new place to explore ...on the sunday am ...should be out there about 9.00 ish
thanks for the heads up Martin ...giggles ...must be all the head work going on around this little shack eh?
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OLowood Motorcyle Swap Meet 21st and 22nd July Au-log10
"redframe" rs "bitsa"  with many contributions from the k100 community ,,with many thanks
MarcS
MarcS
My bike may just be on the road by then. If I am mobile on the brick I will meet you guys there.
K100rt ex plod bike 5/1990.
I have no problem with authority. Just some of the morons that are paid to enforce it.
Charlie have you thought about getting a social secretary. It would take the burden off where and when to go. I do have more free time these days. Lowood Motorcyle Swap Meet 21st and 22nd July 44271  Marc looking forward to the meet up, you need to stop typing and put all your efforts into getting your Brick going.
MarcS
MarcS
@MartinW wrote:Charlie have you thought about getting a social secretary. It would take the burden off where and when to go. I do have more free time these days. Lowood Motorcyle Swap Meet 21st and 22nd July 44271  Marc looking forward to the meet up, you need to stop typing and put all your efforts into getting your Brick going.
I have ordered parts from the UK, Germany and Aust. They are still coming and I am at a loose end until they arrive. The only problem I can have a go at fixing ATM is the bloody annoying park lights. I would love to be fixing the gearbox leak, fitting the dual seat and duck tail, spraying everything with DeoxIT! and fitting my mirrors Lowood Motorcyle Swap Meet 21st and 22nd July 259495 . I too am looking forward to meeting you and Charlie.
@MartinW wrote:Charlie have you thought about getting a social secretary. It would take the burden off where and when to go. I do have more free time these days. Lowood Motorcyle Swap Meet 21st and 22nd July 44271 .
ye Gods no ...no social secretary for this old bloke ...I was fortunate oops unlucky enough to loose the other half quite some years ago now
i did attend her funeral , which some other members may remember .  just to be sure she didn't get out of that box …. giggle ...
hope you make it Marc ...always good get acquainted with a familiar face on the forum that we haven't actually met yet .
tis actually quite amazing the broad spectrum of fellows on the forum ,,,and share the enthusiasm and Komeraderie with other appreciators
we have met some fantastic guys and gals over the years ...and after the initial meeting ...we always catch up whenever we can … always a blast
maybe Matt could make this one ?  apparently he sailed through roadworthy with his rs first go .
and its a nice run up through ipswich along the warrego  then up to fernvale and left to lowood ...will be leaving Goodna caltex about 8.00 am ish
possibly reg fisher (minden area ) may join in as well  )confirmed just Now ...in another place)
cheers guys
Hi Charlie
I'm in  yes the RS went through  rego without a problem
but I have developed a rear main leak, parts just came from motobin  to fix
just trying to plan if I have enough time to replace before the 22nd or after
good to hear matt
the rear main leak , I guess a drip or two out the bell housing ?  ...pretty typical actually ...many have just let it be for a good while ...I think gerty was a drip every now and again for more than a few years ...without too much issues at all ...but if you are going in there ...possibly a new friction plate … unless its very low ks ….more than likely just the oring under the big nut could be the likely issue ???
and about a comfortable days work ...if you've never done it before .
I hope you read the tips on gearbox bolts longer than necessary , heads cut off  to help with the removal and refitting ??
if you need a hand I could be available mate
workshop day ? giggles
Thanks for the offer Charlie
I brought a new oil seal, o ring , nut and the six new clutch bolts and washers + new friction plate because I think mine will most likely be original and clutch cable
+ some extra parts when I do the valve clearances
Planing on trying to do most of the work this weekend  but  I do need to find the  correct dia and tread pitch for the gearbox slide bolts
Do you know what they are off hand  ???
I do need to find the  correct dia and tread pitch for the gearbox slide bolts.  8M x 1.25mm
Thanks Rick  G
Mathew where in Brissie are you located, I might be able to assist.
Tarragindi
just south of the city
If you need a hand or tools that are capable of being carried via panniers give me a yell.
I thought I'd bump this just in case some members haven't seen it. It looks like Sunday is the chosen day. I'm looking forward to catching up.  Lowood Motorcyle Swap Meet 21st and 22nd July 112350
You'll need to be there 6.00 Saturday morning or you will get nothing. Like all swap meets.
Rick how was the weather this morning, nice and brisk for an early morning ride? You're right about Saturday being the best day and due to the fact I am now free I can attend on either day. I probably need to ask the following question what days can those attending make it on.
going sunday regardless
I don't think there is a very high expectation that k parts will be around much anyhow
id be surprised if there was .
laverda concours tomorrow at Cleveland
will be there about 10 am ...Reg fisher will also be there
Matt leitch wont be going to that one ...but he has finished his rear main seal clutch job today ready for next week
@MartinW wrote:Rick how was the weather this morning, nice and brisk for an early morning ride? You're right about Saturday being the best day and due to the fact I am now free I can attend on either day. I probably need to ask the following question what days can those attending make it on.
About -7°C, a cold one but not the worst by any means, -11°C is the coldest it's been here since we moved here 20 years ago.
2°C ATM but its going down like a manhole cover.
Charlie what do you mean no K parts at the swap meet. What about all the K parts at the Samford swap meet, one and a half sets of panniers. Lowood Motorcyle Swap Meet 21st and 22nd July 723598 My mate with the ute is not coming so I'll expect help with getting all my booty home.  Lowood Motorcyle Swap Meet 21st and 22nd July 167893 See you on Sunday. Lowood Motorcyle Swap Meet 21st and 22nd July 44271
Pegasus
Pegasus
@charlie99 wrote:going sunday regardless
I didn't see you there. I got there at 11am. it was too bloody cold to leave Ipswich before 10am.
Not that you missed much if you didn't go. The bikes in the car park were more interesting than those inside!
I parked at the bottom of the 2nd row from the fence, next to a ratty looking K100. I looked out for Gerty!
As there wasn't much there to occupy my attention, I went for a ride down to the Gold Coast after.
The uni joint/s shat themselves at speed without any prior warning noises, destroying the driveshaft and possibly the swingarm and locking the real wheel.
I also destroyed my undies, but kept the bike upright with the rear wheel locked.
That happened at 2.30pm. It was 9.30 pm by the time the bike had been recovered and I finally got back home.
bugga to hear mate ...hope you are all ok ???
that might have been Reg's old k100
sorry I missed you , and yes was quite a show in the car park
@Pegasus wrote:The uni joint/s shat themselves at speed without any prior warning noises, destroying the driveshaft and possibly the swingarm and locking the real wheel.
I think think I would have destroyed more than a set of undies
Think all of the port/ rum in the house would be consumed
Glad to hear your ok
will be at Goodna Caltex …(off the highway service road outbound )  about 8.00 am leaving about 8:15
expect to be at fernvale about 8:45 …
hope we see some others there at Lowood
Hopefully I should be there at the servo Charlie.  I know it well from days gone by.
If I leave home at 7:15am Sunday morning, I should be there easily in time.
cool good to see dave
see you there mate
Charlie I'm aiming to get there by 8.00, if I'm not there by 8.15 I'll see you at the meet. Is the Caltex Goodna the one on the corner of Brisbane Rd and Church St?
Martin,
It's on Brisbane Road, just past Church Street, parallel to the motorway.  You'll pass the BP first, then Church St.
Dave.
Thanks Dave, I'll see you there.
meet point  Caltex
take the Goodna turn off- exit  , some 1 k before actually getting to Goodna , right about the Logan motor way junction
Lowood Motorcyle Swap Meet 21st and 22nd July Meet_p11
Lowood Motorcyle Swap Meet 21st and 22nd July Meet_p10
Just checked the weather predictions. Goodna 0700 4C 0800 8C Lowood 0600 3C, 0900 10C. I just went and dragged out my cold weather gear. cold
yep its been cold out ipswitch ways last few weeks  (relatively for us coastal dwellers )
im glad that we aren't getting there much earlier
I haven't worn my cold weather gear for quite a few years, at least ten. About five years ago I nearly got rid of it but the Honorable Minister for Finance and Recreation put it away, bless her little cotton socks. Around here my winter gear consists of a liner in my summer jacket an Aldi bike shirt and jumper. Should I carry snow chains? Lowood Motorcyle Swap Meet 21st and 22nd July 610153
I just saw my previous post number 666. As I don't want to go to Hell, although it wouldn't require cold weather gear. I thought I'd better post another so now 667. Lowood Motorcyle Swap Meet 21st and 22nd July 44271
Regards a not superstitious Martin.
Pegasus
Pegasus
@charlie99 wrote:yep its been cold out ipswitch ways last few weeks  (relatively for us coastal dwellers )
Tell me about it!
I don't live far from the rear entrance to Amberley RAAF Base.
We've been getting -2 & -3 in the mornings over the last week or so.
I know that's summer weather for Smithy in Guyra.
You know it's bloody cold outside when I open the back door for the cat to go out in the morning and she takes a few steps outside and turns around and comes back inside.
On a positive note, I sourced replacement driveshaft, front yoke and (black) swingarm for the K1100.
I've had the swingarm repainted gold as mine is a 93RS, with gold wheels and swingarm.
Hopefully it will be back on the road in the next week or so.
Andrew
good to hear Andrew
a little ride out today with some of the local K Crew and a wee bit chilly for us lot on the coastal strip
first there was 3 ... an S an Rs and a Rt …
Lowood Motorcyle Swap Meet 21st and 22nd July 20180737
which then became 4
Lowood Motorcyle Swap Meet 21st and 22nd July 20180738
 about to set off for the Lowood Swap Meet a short while later
4 became 6 with the arrival of some other, yet to meet, friends at the swap meet grounds
Lowood Motorcyle Swap Meet 21st and 22nd July 20180739
after a good hunt around the vendors at the meet... Matt scored a win with some parts at great prices ...and a good chat with other "k" riders .as the warmth returned with the sun .
Lowood Motorcyle Swap Meet 21st and 22nd July 20180741
Lowood Motorcyle Swap Meet 21st and 22nd July 20180742
then off for the "long way home" loop around the greater environs of Brisbane and the brisbane valley
thanks for coming along Mat , Martin, Dave , Paul and Reg
a glorious day to be out and about on old K bikes and good mates
A good day out with a bit of a chill around.
An amiable atmosphere to meet some new faces.  If we keep boosting our numbers we may even overtake the Krew.   Cool
