1Back to top Go down    gearbox lube on Tue Jul 03, 2018 8:10 pm
brickrider2
The K-bikes gearboxes - as far as I know - all require GL-5 lubricant. Locally I typically find this in 80-90 and 80-145 (?) weights. There are some who say that Castrol GL-5 Limited Slip is preferred. Can anyone enlighten me on how this differs from your garden variety GL-5 lube?
2Back to top Go down    Re: gearbox lube on Tue Jul 03, 2018 8:41 pm
I very much expect that when the K was designed only the regular 80W90 was available. Seems a lot of 80W140 or 145 about now.
Presumably that Castrol has a moly additive.......some of usadd this in anyway.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now 87,050 miles
1983 K100RS 0011175 Fricka 29,000 miles Damn K Pox
3Back to top Go down    Re: gearbox lube on Tue Jul 03, 2018 10:15 pm
What's more important than the gear oil weight is adding some moly. Once it works its way in in a few hundred miles the bike will shift noticeably more smoothly.
I usually use Mobil 1 75-140 on a 20K interval.
And K bike trannies generally don't wear out. Like many other aspects of Ks they are pretty bulletproof.
Although there's a grub screw in there that can work loose and cause issues.
And if you don't keep the clutch splines properly lubed then you can strip the splines on the input shaft.
4Back to top Go down    Re: gearbox lube on Wed Jul 04, 2018 5:06 pm
+1 on the moly. I add a bit of 1.5 micron powder when I change the oil and where my bikes shifted hard and clunky, especially on downshifts, when I got them, they shift like the best of the riceburners now.
1994 K75S
1992 K100RS
5Back to top Go down    Re: gearbox lube on Wed Jul 04, 2018 7:51 pm
@Point-Seven-five wrote: they shift like the best of the riceburners now.
You obviously don't own a Bandit...
6Back to top Go down    Re: gearbox lube on Wed Jul 04, 2018 11:03 pm
No, but I rode and competed on Hondas for 20 years.
1994 K75S
1992 K100RS
7Back to top Go down    Re: gearbox lube on Thu Jul 05, 2018 12:24 am
brickrider2
maybe try some moly in the Bandit box? Wink
8Back to top Go down    Re: gearbox lube on Thu Jul 05, 2018 6:18 pm
Yup! - Know about those boxes too. Well, up to the late '90s anyway - I've no idea if they've improved since.
