1Back to top Go down   engine suspension bolt spacer Empty engine suspension bolt spacer on Mon Jul 09, 2018 3:43 pm
mister_anger
mister_anger
hello,
In the K100 parts manual I see a spacer between the frame and the engine suspension point at the left/front side.
The parts manual even shows different spacers in different thickness.
I didn't see that spacer when I dismantled my bike.
I could have missed it.
When I installed the frame back I saw a real small gap in between the frame and the enigne point but it closed when I tightened the bolt.
I am talking about less then 1 mm. Would this spacer be real important?
thx,M
2Back to top Go down   engine suspension bolt spacer Empty Re: engine suspension bolt spacer on Mon Jul 09, 2018 3:55 pm
Yes, that spacer is really important. It needs to be in place otherwise the tracking of the motorcycle could be off, which is a dangerous situation. There are specific instructions in the OEM service manual for your year and model of K-bike for torquing up the frame and determining the correct size of that spacer.
3Back to top Go down   engine suspension bolt spacer Empty Re: engine suspension bolt spacer on Mon Jul 09, 2018 5:02 pm
mister_anger
mister_anger
I have the Haynes manual but can't find any info on this spacer.
You say OEM service manual?
4Back to top Go down   engine suspension bolt spacer Empty Re: engine suspension bolt spacer on Mon Jul 09, 2018 5:07 pm
mister_anger
mister_anger
checked again and I found the needed info, thanks
5Back to top Go down   engine suspension bolt spacer Empty Re: engine suspension bolt spacer on Mon Jul 09, 2018 5:55 pm
The spacer also affects vibration damping. It is very important to get those shims right.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now91,850 miles
1983 K100RS 0011175 Fricka 29,495 miles Damn K Pox
