1Back to top Go down   Wanted fuel injectors K100RS 1984 Empty Wanted fuel injectors K100RS 1984 on Thu Aug 16, 2018 6:58 am
K100RSRT
K100RSRT
fuel injectors required K100RS 1984, old ones are seized, postage or shipping to Australia 4211
2Back to top Go down   Wanted fuel injectors K100RS 1984 Empty Re: Wanted fuel injectors K100RS 1984 on Thu Aug 16, 2018 7:19 am
hi there ...there are quite few posts throughout the forums about economy injectors ...from surprising places in fact ...try the search feature in the portal page
good luck
k100-forum/portal
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OWanted fuel injectors K100RS 1984 Au-log10
3Back to top Go down   Wanted fuel injectors K100RS 1984 Empty Re: Wanted fuel injectors K100RS 1984 on Thu Aug 16, 2018 7:36 am
K100RSRT
K100RSRT
Thank you Amanda new to the page after I exhausted facebook thanks...
4Back to top Go down   Wanted fuel injectors K100RS 1984 Empty Re: Wanted fuel injectors K100RS 1984 on Thu Aug 16, 2018 7:47 am
As a last ditch effort try soaking in lacquer thinners. And activate away from the thinners using a 9v battery. You might have to repeat the soaking a few times. If you are close I do have a cleaning and test rig.
Last edited by MartinW on Thu Aug 16, 2018 7:48 am; edited 1 time in total (Reason for editing : Addition)
5Back to top Go down   Wanted fuel injectors K100RS 1984 Empty Re: Wanted fuel injectors K100RS 1984 on Thu Aug 16, 2018 8:03 am
K100RSRT
K100RSRT
Thanks I've soaked in petrol for a few days they are seized I've tried ford falcon injectors but they run rich, was told Hyundai excel fit
6Back to top Go down   Wanted fuel injectors K100RS 1984 Empty Re: Wanted fuel injectors K100RS 1984 on Thu Aug 16, 2018 4:55 pm
nino
Try this german adress www.tills.de
Regards
7Back to top Go down   Wanted fuel injectors K100RS 1984 Empty Re: Wanted fuel injectors K100RS 1984 on Thu Aug 16, 2018 5:01 pm
I was having trouble with a couple of totally seized injectors. I soaked them injector cleaner and sonic bathed them in injector cleaner and they were still seized. While I was at a local European car specialist buying injector parts, I mentioned my seized injectors. He asked what I was using and I said injector cleaner. He said it was too dear and not as efficient as thinners which is what they used. Where are you located?
8Back to top Go down   Wanted fuel injectors K100RS 1984 Empty Re: Wanted fuel injectors K100RS 1984 on Thu Aug 16, 2018 7:14 pm
K100RSRT
K100RSRT
Gold coast QLD cheers for advice I'll try thinners
9Back to top Go down   Wanted fuel injectors K100RS 1984 Empty Re: Wanted fuel injectors K100RS 1984 on Fri Aug 17, 2018 9:53 pm
jahearne
jahearne
Wanted fuel injectors K100RS 1984 1181537659 - John
10Back to top Go down   Wanted fuel injectors K100RS 1984 Empty Fuel Injectors. on Fri Aug 17, 2018 10:36 pm
Pegasus
Pegasus
@K100RSRT wrote:fuel injectors required K100RS 1984, old ones are seized, postage or shipping to Australia 4211
The injectors from a 1.8L Hyundi Excel fit and work well.
Plenty of them at the car wreckers.
Cost me $20 for the set I fitted to a mate's 84 K100.
11Back to top Go down   Wanted fuel injectors K100RS 1984 Empty Re: Wanted fuel injectors K100RS 1984 on Sun Aug 19, 2018 8:31 pm
club_c
club_c
BTDT on my ‘85 RS. Mine used injectors came from an 80’s Ford Ranger pick up (ute to you) and worked well.  Im not sure what that is in Oz. I had a professional place try to clear my originals with no joy.
1988 K100RS SE VIN 01477554
