1Back to top Go down    Sticky Exhaust connector on Sun Sep 02, 2018 6:20 am
deonmartin
deonmartin
Morning to the Forum.
I am stripping the K100RT and cannot remove the exhaust connector?
I eventually cut the silencer box off with an angle grinder but the connector remains stuck to the four exhaust pipes and I am cautious that any more force will damage the pipes.
Any suggestions?
Thank you and all the best.
DMC
2Back to top Go down    Re: Sticky Exhaust connector on Sun Sep 02, 2018 8:17 am
@deonmartin wrote:Morning to the Forum.
Any suggestions?
Morning DMC,
Have a look at this post:
http://www.k100-forum.com/t10489-stuck-exhaust-pipes#126113
The pipes can get extremely tight in the collector but they are quite thick walled and you are unlikely to damage them by using the lever method I used. Whacking them with a large hammer, however, is likely to result in unwanted dents and dings.
Hope this helps
Paul
"Gretel" K100LT 1989 (Silver Grey) (VIN 0177324 Engine No. 104EA 2789 2211) - 4th+ owner. September 2015 (58,500miles and counting....). Cat C Insurancewrite-off rebuild Feb 17
"Donor" K100LT 1990 (Red) (VIN 0178091 Engine No. 4489 2024) - 6th & final owner (crash write-off now donor bike). June 2012 (73,000 miles) to November 2013 (89,500 miles)
3Back to top Go down    Sticky Exhaust connector on Sun Sep 02, 2018 2:42 pm
deonmartin
deonmartin
Good evening from Pretoria.
Thank you to Paul - The Born again eccentric.
I will make a renewed effort tomorrow based on the guidance from the guys that dealt with this problem in the past.
Utilizing the leverage method seems to me be the best and I will in addition spray some "stuff" on the surface where the pipes meet the header muffler.
Keep you posted.
Have a great evening.
DMC
