1Back to top Go down    Bug and Tar removal on Tue Sep 18, 2018 4:01 am
Rickmeister
Rickmeister
Dear All,
With the huge amount of knowledge and wisdom on this truly magnificent forum, is there anyone out there in cyberville who has a neat way of removing dead insects and tar that is splattered all over the front of the bike and helmet visor after a few days on the road, esp here in Aus. I've tried all manner of stuff (WD40, Bug and Tar Remover, Citrus oil, Eucalyptus oil, kerosene, etc etc. (Haven't tried hydrochloric acid yet, for fear of the collateral damage!!)
A foolproof solution could be a real earner!!
Cheers, Rickmeister.
2Back to top Go down    Re: Bug and Tar removal on Tue Sep 18, 2018 4:47 am
Rickmeister,
I have used truck wash...CT18. Mix the stuff 1/3 water in a little spray bottle, spray on parts and leave for about an hour. Pressure cleaner will move it.
Your could try an angle grinder...it is quicker.
1983 K100basic vin 0003960 colour red
1987 K100RT vin 0094685 colour, orange peel, sorry, pearl
3Back to top Go down    Re: Bug and Tar removal on Tue Sep 18, 2018 7:17 am
Try using a paste of bicarbonate soda and water on a sponge to rub a section then wash off with clean water. Probably try on an inconspicuous part first.
We have used it on the car fronts for many years.
95 K1100LT 0232224; 90 K75 6427509; 87 R80G/S PD 6292136
4Back to top Go down    Re: Bug and Tar removal on Tue Sep 18, 2018 7:30 am
@Stan wrote:Rickmeister,
I just mix it the same, brush it on and Leave overnight and hose off in the morning.
5Back to top Go down    Re: Bug and Tar removal on Tue Sep 18, 2018 12:16 pm
brickrider2
brickrider2
Have you tried hydrogen peroxide in a spray bottle? It dissolves the insects. Road tar? Not much help with that.
6Back to top Go down    Bug and Tar removal on Tue Sep 18, 2018 7:31 pm
Turps will dissolve road tar and won t effect the bodywork, but will dissolve wax if you are a wax head. Not for ears.
Suzuki V Strom 650DL 2011. Gasp, chain driven.
7Back to top Go down    Re: Bug and Tar removal on Tue Sep 18, 2018 11:56 pm
If it is only a bug problem...degreaser could do the job. After all you are dealing with oil in the bug. What is the last thing that goes through a bug's head when it hits the windscreen?.....It's bum.
8Back to top Go down    Re: Bug and Tar removal on Wed Sep 19, 2018 6:06 am
Corkboy
Corkboy
I use Autoglym intensive Tar remover.
formulated specifically for the task, and goes a great job at dissolving that black road tar.
Lasts a long time and does a great job. Expensive to buy, but I suppose it depends on how much you value your time.
'87 K100RS 0140995 (Gone)
'97 K1100LT 0188024 (Gone)
'08 Transalp 700
9Back to top Go down    Bug and Tar Removal on Thu Sep 20, 2018 5:14 am
Tom FKR
Tom FKR
G'day all, just tried the C18 mixture as suggested by Stan and Smithy. After last weekend's ride of nearly 2000km, plenty of bugs were collected on the way. The C18 mixture worked a treat for the bugs but the tar is another story. Thank you for that idea. Cheers Tom
1993 K75 Slightly Modified
2010 BMW F650GS Twin
10Back to top Go down    Re: Bug and Tar removal on Thu Sep 20, 2018 10:21 am
yamaguzzi
yamaguzzi
I use NAPTHA .It won't hurt paint ( we use it to clean paint between coats) and it's cheap
https://facebkfugitive.blogspot.com/
11Back to top Go down    Bug and tar removal on Fri Sep 21, 2018 12:52 pm
norton71
norton71
If you are going for a decent long ride ...why not just use some of this stuff..cheap and easy, and a temporary bonus colour change too if you want it; with original paint protected and retained. Just leave enough of it over hanging to grab so you can peel it off with both the bugs and tar... make sure you get something plastic/fairing compatible
.....https://www.supercheapauto.com.au/shop-by.../paint-and.../vinyl.../removable-paint ......
or check videos on removable vinyl car paint video you tube
Very Happy
12Back to top Go down    Re: Bug and Tar removal on Fri Sep 21, 2018 6:26 pm
If you don't want to change the colour it is available from Rust-Oleum and Plasti Dip in clear. I nearly used it to protect my belly pan but ended up using bed liner.
13Back to top Go down    throw on a wet towel on Mon Sep 24, 2018 1:49 am
nvboy
nvboy
When I travel on the bike and stay in hotels at the end of the day I just wrap my helmet in a towel soaked in hot water and leave it overnight. In the morning the bugs just slide off. Can't help too much with road tar, though.
nvboy
14Back to top Go down    Re: Bug and Tar removal on Mon Sep 24, 2018 8:56 am
@nvboy wrote:When I travel on the bike and stay in hotels at the end of the day I just wrap my helmet in a towel soaked in hot water and leave it overnight. In the morning the bugs just slide off. Can't help too much with road tar, though.
nvboy
+1 here. I also drape a wet towel over the wind shield and the buggy parts of the fairing for 10-15 minutes. Bugs come right off.
1994 K75S
1992 K100RS
