1Back to top Go down   Just A question  Empty Just A question Tue Nov 06, 2018 6:58 pm
yamaguzzi
yamaguzzi
How often or how many miles can you go without replacing the fuel filter? I put all new stuff in the tank and cleaned the tank with acid to like new condition 6000 miles ago (about a year and a half ago) and wonering if it's time to change the filter.There is nothing wrong with the way the bike runs for the most part but the other day I really got on it and at about 5500 rpm it started to act funny. Slowed down and everything was good again  so I'm thinking it might be that time.Anyone?
2Back to top Go down   Just A question  Empty Re: Just A question Tue Nov 06, 2018 7:17 pm
6000 miles is about 120 gallons of gas.
When you consider that a lot of automobiles can go 150,000+ miles which uses about 5,000 gallons running the same gas through similar filters you have to wonder how often you really need to change that filter.
3Back to top Go down   Just A question  Empty Re: Just A question Tue Nov 06, 2018 7:21 pm
yamaguzzi
yamaguzzi
That's a good point  So I guess I should look at something else as the cause of crappy high speed performance like corrosion on some connection or leaking vacuum lines
4Back to top Go down   Just A question  Empty Re: Just A question Tue Nov 06, 2018 7:31 pm
I replace whenever neccesary, most when I just buy another K.
Just A question  Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
5Back to top Go down   Just A question  Empty Re: Just A question Tue Nov 06, 2018 7:34 pm
I last replaced mine about 60,000 miles ago, just when I bought the bike.
6Back to top Go down   Just A question  Empty Re: Just A question Tue Nov 06, 2018 8:06 pm
yamaguzzi
yamaguzzi
Thanks guys . Now I am pointed in the right direction and I will start going over the hoses and connections.
7Back to top Go down   Just A question  Empty Re: Just A question Tue Nov 06, 2018 9:39 pm
Easy test.  Pull the fuel filter and try to blow through it.  It should be pretty easy.
Napa 3032 filter is readily available in the US and only about $5.
Miles/gallons aren't the only thing that mess up fuel filters. If a decent amount of water sits in a fuel filter it can swell the fibers and restrict flow.
8Back to top Go down   Just A question  Empty Re: Just A question Wed Nov 07, 2018 3:04 am
E5 and E10 is hydroscopic, means it attracts water, like brakefluid.
And that crap gets old much faster than the old fuel, can make a mess in the filter.
Last year in Germany, I was able to take Supreme fuel 102, made a smooth racing bike of the old K Smile
9Back to top Go down   Just A question  Empty Re: Just A question Wed Nov 07, 2018 9:00 am
Have you checked the valve clearance?  Tight valves can make it break up.  A bad plug or plug wire can cause problems a well.  How is the air filter?
10Back to top Go down   Just A question  Empty Re: Just A question Wed Nov 07, 2018 11:05 am
Arlina wrote:E5 and E10 is hydroscopic, means it attracts water, like brakefluid.
Smile
It's actually Hygroscopic, the ability of a chemical compound to absorb or attract water.
Hydroscope is a tool, similar to a telescope built for observing things underwater.
11Back to top Go down   Just A question  Empty Re: Just A question Wed Nov 07, 2018 12:52 pm
Thanks TWB, mistype in the morning Very Happy
12Back to top Go down   Just A question  Empty Re: Just A question Wed Nov 07, 2018 12:56 pm
Arlina wrote:Thanks TWB, mistype in the morning Very Happy
No worries, Arlina. That's what comes from having a schoolteacher for a father.
study scratch
13Back to top Go down   Just A question  Empty Re: Just A question Wed Nov 07, 2018 1:05 pm
Two Wheels Better wrote:It's actually Hygroscopic, the ability of a chemical compound to absorb or attract water.
Both E10 gasohol and brake fluid are also hydrophilic.   If hydro is one of your favorite prefixes, there you go.
That is why ethanol both contributes to octane level in fresh fuel but also creates starting problems in stored fuel. Just A question  177381 It's also why brakes fade when using old brake fluid under hard usage.
14Back to top Go down   Just A question  Empty Re: Just A question Wed Nov 07, 2018 2:57 pm
Water causes much different problems in gas vs. brake fluid.  The problem with old brake fluid that's absorbed water is that water is more compressible than brake fluid which is why brakes with old fluid get mushy.
Water in gas causes different problems.
15Back to top Go down   Just A question  Empty Re: Just A question Wed Nov 07, 2018 3:01 pm
duck wrote:Water in gas causes different problems.
No kidding? Laughing
16Back to top Go down   Just A question  Empty Re: Just A question Wed Nov 07, 2018 3:12 pm
brickrider2
brickrider2
Water is compressible?  I've never heard that before.
I thought the problem with water in brake fluid is it's tendency to boil at high temperatures, passing to a gas state, which would compress.
1996 K1100LT
17Back to top Go down   Just A question  Empty Re: Just A question Wed Nov 07, 2018 4:03 pm
Yes, water is more compressible than brake fluid. Brakes with water in them will be mushy at room temperature.
And the boiling point is an issue as well.
Rust caused by water in brake components can also be an issue.
18Back to top Go down   Just A question  Empty Re: Just A question Wed Nov 07, 2018 8:41 pm
What about verdigris? Smile
19Back to top Go down   Just A question  Empty Re: Just A question Fri Nov 09, 2018 4:32 pm
ERasberg
ERasberg
brickrider2 wrote:Water is compressible?  I've never heard that before.
Yes this is correct.
Though it is true that water is not 100% in-compressible (nothing is), water in liquid state is still considered high in density and not necessarily more compressible than brake fluid.
The 4 critical purposes a brake fluid has to fulfil :
1. Maintain a high boiling point
2. Maintain a specific viscosity range
3. Prevent corrosion
4. Maintain low compressibility
In addition, the brake fluid must maintain [pretty much] the same compressibility across a wide temperature range, say from freezing to way above boiling temperatures.
Water obviously does not do that, as it changes states from solid via liquid to gas and therefore also moves the values of both compressibilty and viscosity in the process.
Mixing just a tiny bit of water into the brake fluid will hence impact all of the above parameters preventing the brake fluid from fulfilling its purpose.
3% water is apparently the critical limit for brake fluid.
Best regards,
Einar
Present
1988 K100 RS SE - VIN# 0146971K100RS - 105,000 km
1998 R1200C
1971 R75/5
Previous
1999 Virago XV125
1981 R65
20Back to top Go down   Just A question  Empty Re: Just A question Fri Nov 09, 2018 5:50 pm
Its not difficult in mountain, very hot or racing conditions to get brakes extremely hot. Brake fluid will have a decent boiling temperature, water does not and will become steam which will of course be compressible and result in brake failure. It does not have to reach 100c for these things to happen,
21Back to top Go down   Just A question  Empty Re: Just A question Fri Nov 09, 2018 7:46 pm
ERasberg
ERasberg
Regarding the original question, when to change fuel filter I would day unless you encounter regularly low quality fuel the general recommendation is to change every 40 000 km.
Present
1998 R1200C
1971 R75/5
Previous
1999 Virago XV125
1981 R65
