1Back to top Go down    Newbie 1985 K100 restore on Mon Nov 05, 2018 6:19 am
warmas
warmas
Greetings:
After rescuing, am attempting resusitation to above.
I have a few airheads, am new the electronic Ks.
2Back to top Go down    Re: Newbie 1985 K100 restore on Mon Nov 12, 2018 6:52 pm
DBRMN
DBRMN
@warmas wrote:Greetings:
Good luck you'll need it, jokes you'll be fine!
http://dbrmn.kforum-tech.com
3Back to top Go down    Re: Newbie 1985 K100 restore on Thu Nov 15, 2018 4:42 pm
christymahon
christymahon
The great thing about the electrics is they're incredibly logical. They work or they don't. Most failures are age related, not usage related. They occur at connections in the loom and inside relays because all connections everywhere deteriorate in atmosphere. Once they're cleaned up or replaced, lubed and protected they're good as new.
4Back to top Go down    Re: Newbie 1985 K100 restore on Fri Nov 16, 2018 7:16 am
DBRMN
DBRMN
@christymahon wrote:The great thing about the electrics is they're incredibly logical. They work or they don't. Most failures are age related, not usage related. They occur at connections in the loom and inside relays because all connections everywhere deteriorate in atmosphere. Once they're cleaned up or replaced, lubed and protected they're good as new.
Yeah thats a very good point, I found wiring up the Motoscope Mini initially really hard but once you understand BMW electrics a bit more it makes much more sense.
