1Back to top Go down   1988 final drive needed Empty 1988 final drive needed on Fri Nov 23, 2018 3:21 pm
Policebikescomau
Policebikescomau
Morning all ,
Would anyone have a final drive to fit a base (factory naked) model knocking about? I have one from a K75 to trade/sell.
Cheers, Alex
http://www.policebikes.com.au
2Back to top Go down   1988 final drive needed Empty Re: 1988 final drive needed on Fri Nov 23, 2018 6:16 pm
Why can't you use the K75 unit you already have?  Except for reduction ratios, Monolever final drives are all the same.
3Back to top Go down   1988 final drive needed Empty Re: 1988 final drive needed on Fri Nov 23, 2018 8:56 pm
Are the final drives you have drum or disc brake. What final drive do you require drum or disc.
4Back to top Go down   1988 final drive needed Empty Re: 1988 final drive needed on Sat Nov 24, 2018 3:49 am
Matt I have access to a complete final drive with wheel. I can get it pretty cheap PM me if you need it and I'll give you the details.
5Back to top Go down   1988 final drive needed Empty Re: 1988 final drive needed on Sat Nov 24, 2018 4:11 am
Policebikescomau
Policebikescomau
@MartinW wrote:Are the final drives you have drum or disc brake. What final drive do you require drum or disc.
Hi Martin
The K100 was only fitted with a discs.
6Back to top Go down   1988 final drive needed Empty Re: 1988 final drive needed on Sat Nov 24, 2018 4:24 am
alex you only posted  "88 final drive required " no specification if it was for a k75 - k100 or anything
martin was trying to help with a logical question about what drive you are offering in exchange, or what is required , as the k75 came out with different options  and so did the 88 model k100 ., rs , lt etc  so none of us know what actually you are asking for ...
a bit of clarity might help in the topic description  and original post by you
there is no description in your profile add ons to what type of bike it is going to fit
maybe revisit your original post and clarify please ???
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%O1988 final drive needed Au-log10
7Back to top Go down   1988 final drive needed Empty Re: 1988 final drive needed on Sat Nov 24, 2018 4:29 am
My physic ability seemed to have diminished. As per Charlie you need to be more specific.1988 final drive needed 610153
8Back to top Go down   1988 final drive needed Empty Re: 1988 final drive needed on Sat Nov 24, 2018 4:40 am
Policebikescomau
Policebikescomau
Ah, that's the getting up too early problem, so let me clarify...
The bike is a 1988 BMW K100 base model, and it came in lots of boxes.
After checking those boxes I found I only had a black K75 final drive, and that's what's currently fitted to the bike.
So, I'm looking for a BMW K100 base model final drive, and happy to trade /part ex the K75 unit I currently have.
9Back to top Go down   1988 final drive needed Empty Re: 1988 final drive needed on Sat Nov 24, 2018 4:53 am
alex just a question here , how do you know its a k75 final drive , they re all the same except for possibly the gear ratio in 88
and what gear ratio are you seeking   "basics" were rare out here  primarily rs or lt k100 were the standard  in 88
so again clarity please ...what is stamped on the final drive you have to offer as exchange ...spline count ..and what are you seeking ...88 is usually 20 tooth spline  but what gear ratios  are you seeking   black or aluminium finish ?
10Back to top Go down   1988 final drive needed Empty Re: 1988 final drive needed on Sat Nov 24, 2018 5:06 am
Policebikescomau
Policebikescomau
K75 is written on the final drive in white marker
As far as gear ratio goes  as close to the basic specifications as possible, or failing that probably a unit from an RT in aluminium.
11Back to top Go down   1988 final drive needed Empty Re: 1988 final drive needed on Sat Nov 24, 2018 5:11 am
Pictures of the unit and splines would also help. As would the ratio stamped on the housing.
12Back to top Go down   1988 final drive needed Empty Re: 1988 final drive needed on Sat Nov 24, 2018 5:24 am
Policebikescomau
Policebikescomau
@MartinW wrote:Pictures of the unit and splines would also help. As would the ratio stamped on the housing.
Indeed it would  however, its at my workshop attached to the bike ,and I'm at home drinking a beer, so photos will have to wait.
13Back to top Go down   1988 final drive needed Empty Re: 1988 final drive needed on Mon Nov 26, 2018 7:02 am
Check if the basic K100 has 16 or 20 spline final drive. All K75 are 20 spline.
If the splines don't match you will need to get the drive shaft to go with it.
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 102,500 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell Now 36,188  miles
14Back to top Go down   1988 final drive needed Empty Re: 1988 final drive needed on Wed Nov 28, 2018 1:47 am
Basic2
Basic2
@charlie99 wrote:alex just a question here , how do you know its a k75 final drive , they re all the same except for possibly the gear ratio in 88
Alex,
My 11/87 K100CJ Basic/2 has a unfinished aluminium final drive, with a 37/11 ratio.
K100 Basic 2
11/1987 6308319K100CJ
Marakesh Red
