1Back to top Go down   Gear switch stuck in 1??? Empty Gear switch stuck in 1??? Wed Nov 28, 2018 2:41 pm
yamarider
yamarider
Not sure if I have a faulty gear switch, but lunch box is showing 1st gear, regardless if gear switch is connected or not. Changing gears or pulling clutch does not make any difference. As a result I can't start the bike... Any suggestions?
Checked and cleaned plugs at lunch box and rear right frame connection. I'm running out of ideas.
http://www.yamarider.com
2Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Wed Nov 28, 2018 3:50 pm
Pull in the clutch to start. Use this until you are able to debug the problem.
3Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Wed Nov 28, 2018 4:42 pm
yamarider
yamarider
I tried that... But even with clutch pulled and won't start.... Can I disable the clutch sensor temporarily to eliminate that problem?
4Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Wed Nov 28, 2018 4:55 pm
Your clutch switch is either broken or disconnected. (Probably broken.)
If you're certain that it's not just disconnected under the tank then you can cut the wires to it and short them to each other to send power to the start button.
Be VERY CAREFUL if you do this as it's a 12V circuit so if you cut the wires to it and have exposed wires then you want to make sure you do not to let a 12V+ wire ground to anything.
The other way to get power to the start button is to pull the tank and find the connector for the right combo switch.  Look for the terminal that has two black/green wires to it. (Those are the two wires from gear indicator in the cluster and clutch switch that send power to the start button.)  Put 12V to that and it will give power to the start button.
5Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Wed Nov 28, 2018 5:11 pm
yamarider wrote:Not sure if I have a faulty gear switch, but lunch box is showing 1st gear, regardless if gear switch is connected or not. Changing gears or pulling clutch does not make any difference.
Which model and year is this moto?
6Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Wed Nov 28, 2018 8:56 pm
yamarider
yamarider
It's a 1994 K1100LT
7Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Wed Nov 28, 2018 9:10 pm
Sidestand switch problem??
8Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Wed Nov 28, 2018 9:16 pm
robmack wrote:Sidestand switch problem??
To expand robmack's question.
Does the starter engage? Do you hear the fuel pump prime when the ignition is turned on?
9Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Wed Nov 28, 2018 9:38 pm
yamarider
yamarider
No starter, no pump... Just dash lights come on, except neutral light....
10Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Thu Nov 29, 2018 6:00 am
Side stand switch will stop it starting, even if the clutch switch is good. Its the most likely cause of your problem.
You can survive no problem with the gear switch out of order, but to do that you need the clutch switch good and the side stand switch good. You can wiggle the side stand switch under the bike, that may sort it for you..
11Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Thu Nov 29, 2018 9:49 am
92KK 84WW Olaf wrote:Side stand switch will stop it starting, even if the clutch switch is good. Its the most likely cause of your problem.
A quick fix for a side stand switch that isn't engaging is to put a small piece of vacuum hose over the tang of the switch that gets pushed when the side stand comes up.
(I'd assumed it was a 2V bike since there's no bike listed in the OP's signature.)
12Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Thu Nov 29, 2018 11:48 am
yamarider wrote:No starter, no pump... Just dash lights come on, except neutral light....
My copy of the 1994–95 K1100 Rider's Manual indicates the starter will operate when the side stand is down but the engine won't start until the side stand is raised. Yamarider's starter does not operate.
13Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Thu Nov 29, 2018 12:03 pm
Then the pointer is the clutch switch being faulty.
But oddly mine doesn't work with side stand down.
14Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Thu Nov 29, 2018 12:41 pm
Laitch wrote:My copy of the 1994–95 K1100 Rider's Manual indicates the starter will operate when the side stand is down but the engine won't start until the side stand is raised. Yamarider's starter does not operate.
Maybe the editor of the manual was engaging in artistic license. Smile
Yours is a '97, Olaf, so perhaps the safety system was modified by then.
15Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Thu Nov 29, 2018 5:44 pm
yamarider
yamarider
Hurray - whoever put money on the faulty clutch switch shall receive a full payout!
To make matters worse, I also managed to swap fuel and gear selector plugs around, which look exactly the same and caused the gear indicator to permanently show 1.
Now, next question: is there any trick to get the clutch switch out? It's pretty tight!
And last question: there is no way way too get the gear selector switch out without taking the swing arm out, is there?
Thanks again for all your help! Now I can sleep again...
16Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Fri Nov 30, 2018 7:04 am
Well if you fix the connector issue on the gear selector switch it might read right so do that first.
BUT the only fix is swing arm out. Been there and lived 3 years with a bad switch......Even though guys repair them I simply replaced mine.
Just make sure clutch switch is good. Its tight but not sure is it a micro switch or not. The one on early Ks is a torpedo job and just unscrews out like a spark plug......if its like that screw in the new one BEFORE making the connections as the cable must turn as you screw it in.
17Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Fri Nov 30, 2018 3:08 pm
yamarider
yamarider
Hot wiring the clutch switch and swapping the fuel and gear selector plugs got the engine running, but I still won't get neutral light or correct gear indication. ... And I had the swing arm out last week... Aaaaaaarghhhh
18Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Fri Nov 30, 2018 4:24 pm
Before you tear your bike apart you can do some fairly simple diagnostics to confirm if the GPI switch is the issue.
Link:  http://bit.ly/kbikegpi
19Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Fri Nov 30, 2018 6:08 pm
yamarider wrote:Hot wiring the clutch switch and swapping the fuel and gear selector plugs got the engine running, but I still won't get neutral light or correct gear indication. ... And I had the swing arm out last week... Aaaaaaarghhhh
Was the gear switch working ok before you took out the swing arm?
20Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Fri Nov 30, 2018 6:55 pm
yamarider
yamarider
No. I think it was faulty before...
21Back to top Go down   Gear switch stuck in 1??? Empty Re: Gear switch stuck in 1??? Sun Jan 06, 2019 5:50 am
yamarider
yamarider
just to let you know - I was able to rebuild the gear selector switch with parts from another switch as the springs were broken resulting in the fault. Now she starts (and shows gears) again... Gear switch stuck in 1??? 723598
