1Back to top Go down   Parts To Order Empty Parts To Order on Sat Jan 12, 2019 10:36 pm
prince
prince
I want to order a couple of parts mainly for my new K bike.
It helps the shop I order through if I order a couple of $hundred worth of parts to make it worthwhile for him. He is a good guy so I don't mind.
My K100RT is in really fine condition but I want to pull the transmission to check the splines, etc just because of age and unknown service history.
I think I should order a spare clutch cable.
Can you think of any other parts I should order to replace just because of age? Seals, etc?
Paul
1984 Honda V65 Magna
1985 BMW K100RT
2011 BMW K1600GTL (gone)
2018 BMW K1600GTL
2Back to top Go down   Parts To Order Empty Re: Parts To Order on Sat Jan 12, 2019 11:04 pm
Crank case breather hose. 11151460480
You might want to consider replacing the boots between the throttle bodies and cylinder head. 11611460408 (Qty 4)
Spare throttle cable.
Fuel lines. (But you can replace those with generic hose that's rated for fuel injection.)
3Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 12:14 am
Woodie
Woodie
If you are going to remove the clutch you might want to consider the bolts, washers, hex nut and O-ring.  A rear main seal might be in order as well while you are in there.  A rebuild kit for the oil/water pump is good to have as well.  You'll have no problem meeting your minimum.   Very Happy
1985 K100RT
52667
4Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 12:53 am
Alternator monkey nuts, starter brushes.
5Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 1:30 am
@MartinW wrote:Alternator monkey nuts, starter brushes.
Both good suggestions but I wouldn't bother with those unless you're pushing 100K miles or greater.
JM02
6Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 5:55 am
nobbylon
nobbylon
I wouldn’t order anything until I’d taken it apart and found out what I needed. Generic HP fuel hose is ok but the section from regulator to tank needs rerouteing as the original is preformed so as not to kink.
These bikes hold up really well so no need for blind spending.
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
7Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 10:27 am
@nobbylon wrote:Generic HP fuel hose is ok but the section from regulator to tank needs rerouteing as the original is preformed so as not to kink.
I don't understand this comment.  I have four K75s and a K100 all running generic fuel line and this is not an issue. The only fuel line that kinks at all is the one from the fuel rail to the FPR but they all run just fine in spite of that.
8Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 10:51 am
nobbylon
nobbylon
Parts To Order Fe9ea710
This is the line to watch if you fit normal non pre formed hose but you obviously have it covered so i’ll shut up.
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
9Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 11:00 am
nobbylon
nobbylon
Both my K100’s had split crank case vent hoses so check that,
Parts To Order B39fa810
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
10Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 11:26 am
@nobbylon wrote:Parts To Order Fe9ea710
Thanks. Your picture helps me better understand your comment.  The next time I have an air box removed (hopefully never) I'll take a picture of what a generic line looks like there.
11Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 2:37 pm
I had a problem with not running the preformed line to the FPR when I tried to run generic hose. On really hot days the line would collapse causing extremely bad running to the point of being nearly unrideable. As a temporary solution I added another foot of line and followed a more circuitous route. The problem was cured with the fitting of a spring over the end of the line where it fed back into the tank. If you only ride in cold climes it will probably not be a problem, as the days it collapsed was 35C and running in slow stop start traffic.
Regards Martin.Parts To Order Unicoi10
12Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 3:09 pm
nobbylon
nobbylon
like this,
Parts To Order 1a5a1b10
I changed mine last year, ran like a dog until I figured out the line was collapsed.
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
13Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 3:21 pm
Only mine was at the other end, and mine ran more like a hairy goat. It hadn't been a problem until the temperature shot up and encountered traffic.
14Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 5:25 pm
@Woodie wrote:If you are going to remove the clutch you might want to consider the bolts, washers, hex nut and O-ring.  A rear main seal might be in order as well while you are in there.  A rebuild kit for the oil/water pump is good to have as well.  You'll have no problem meeting your minimum.   Very Happy
I agree 100% with that lot. Also drive shaft boot, clutch pivot boot, do gearbox seals too, unless you know they are good then add alternator monkey nuts. I did the whole lot on mine in 2017 as it made so much sense to do everything in there. Takes a bit more effort but worth pulling the bell housing and cleaning sprag clutch.
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
15Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 7:29 pm
prince
prince
Thanks everyone
Paul
1985 BMW K100RT
2018 BMW K1600GTL
16Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 7:30 pm
Install a new fuel filter if you don't know how long that one has been in service.
1995 K75 73,000 miles
Parts To Order Usa-lo10
17Back to top Go down   Parts To Order Empty Re: Parts To Order on Sun Jan 13, 2019 8:06 pm
@Laitch wrote:Install a new fuel filter if you don't know how long that one has been in service.
This.  Don't get a BMW filter as they are overpriced.  Napa 3032 is what I use.
18Back to top Go down   Parts To Order Empty Re: Parts To Order on Mon Jan 14, 2019 12:04 pm
prince
prince
In need a translation into Canadian for "monkey nuts".
What are they? Smile
Paul
1985 BMW K100RT
2018 BMW K1600GTL
19Back to top Go down   Parts To Order Empty Re: Parts To Order on Mon Jan 14, 2019 12:09 pm
pprince wrote:In need a translation into Canadian for "monkey nuts".
Parts To Order Monkey10
The black 'rubber' cush drive/dampers, you need 3 of them for the alternator. They wear.
20Back to top Go down   Parts To Order Empty Re: Parts To Order on Mon Jan 14, 2019 12:15 pm
prince
prince
ah ha
I see said the blind man.
I was thinking like in nuts and bolts.
Paul
1985 BMW K100RT
2018 BMW K1600GTL
21Back to top Go down   Parts To Order Empty Re: Parts To Order on Mon Jan 14, 2019 12:19 pm
Don't worry, I got confused when I was told about them. Had cause to take the alternator off the K100RT but I had seen black rubber bits around the place and knew what it was.
22Back to top Go down   Parts To Order Empty Re: Parts To Order on Mon Jan 14, 2019 12:24 pm
Here's what monkey nuts look like - part 12311464877 (Qty=3)
Parts To Order AcXAGxx
