1Back to top Go down   Tail light problem Empty Tail light problem on Thu Jan 24, 2019 6:04 am
Today at a rego inspection the tail light on the K100RT refused to work.
Thought it was a bulb.  The bulb looks fine and tests OK in the brake light bulb holder.
The multimeter says I have 10.7v at the tail light wires and at the terminals in the bulbholder, but when I fit the bulb it has 0 volts at the spade terminals??  The brake light which is working also shows around 10.7 so tahts not the problem itself.
Have tried a different bulb holder, a different BMU, have tried other bulbs.
I'm not strong with electrics.  If I can't beat this easily, I'll probably justbypass the BMU and take power direct to the bulb.
Any ideas?
The one last thing I can think to check is if the trailer wiring is at fault by disconnecti ng it temporarily
'87 K100RS/HRD sidecar (1100 motor)  sc25
'92 K100RS-16v (Paint it Black)
Tail light problem K-dogs10
2Back to top Go down   Tail light problem Empty Re: Tail light problem on Thu Jan 24, 2019 6:25 am
Good thinking about the trailer connection. Many years ago when the round style of connector was in a mate had all sorts of things go wrong....blinkers blow, but random, left/right....stop light etc.. Turns out that the young son had lifted the flap of the connector and placed a one cent piece in there...for safe keeping. Rolling around shorting out pins caused major headaches and no one looked.
Good luck.
3Back to top Go down   Tail light problem Empty Re: Tail light problem on Thu Jan 24, 2019 7:44 am
volts but no current usually means that the connection is being made ...but just by a hairs breath of copper
is there a take off point , splice into the wiring before the bulb holder ?
is there a good earth wire ?
try measuring between the bulb holder positive ...and a good frame ground ...like back at the gearbox
or alternatively run an earth wire to the bulb holder  from the g box connection  just to prove that path is bad
once you prove the issue ...easier to solve ???
good luck Al
ooops forgot to mention  we have seen a few times that the taillight loom has been caught up behind the top rear shock mount bolt - washer , shorting , fracturing the internal cables etc ...worth a look at least
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OTail light problem Au-log10
4Back to top Go down   Tail light problem Empty Re: Tail light problem on Thu Jan 24, 2019 5:57 pm
The earth is a wire shared by both the tail light and the brake light.  The brake light works reliably, to me that indicates no earth problem.  Can check that just the same.
He passed it anyway, knowing that it will get fixed Smile, made comments about throttle not returning quickly also, I think its time for a new throttle gear.
5Back to top Go down   Tail light problem Empty Re: Tail light problem on Thu Jan 24, 2019 7:59 pm
The BMU monitors the tail light, so it may be related to a problem inside the BMU and not related to any wiring fault. If when you were measuring the voltage, you did so by probing between the active terminal on the bulb and the frame earth point, then 0V could result if the driver in the BMU was faulty. Just taking a WAG here because I actually don't know how the BMU is constructed.
6Back to top Go down   Tail light problem Empty Re: Tail light problem on Thu Jan 24, 2019 8:02 pm
With regard to the slow throttle return...see how much gunk (old grease, dirt etcetera) is in the assembly.
I did the same and, after giving it a good clean-out (lubed it with silicone spray instead of shoving grease in there), the return action improved markedly.
(thanks Duck for the silicone tip)
7Back to top Go down   Tail light problem Empty Re: Tail light problem on Thu Jan 24, 2019 8:32 pm
You can remove the BMU and jump the connections in the BMU connector to eliminate the BMU as the culprit.  (What I do to run LEDs.)
1) Short the front brake switch wire (Gray/Red) and the rear brake switch wire (Gray/Green) to the rear brake light wire (Gray/Yellow.)
2) Short the tail light power wire (Gray/White) to the tail light wire (Gray/Black)
Also, check Fuse #2 as that is power to the tail and parking light.
Does the tail light work when the ignition switch is in the first position? It should.  If it works in the first position but not the full on position then it could be a flaky ignition switch.
8Back to top Go down   Tail light problem Empty Re: Tail light problem on Fri Jan 25, 2019 4:41 am
@robmack wrote:The BMU monitors the tail light, so it may be related to a problem inside the BMU and not related to any wiring fault.  If when you were measuring the voltage, you did so by probing between the active terminal on the bulb and the frame earth point, then 0V could result if the driver in the BMU was faulty.  Just taking a WAG here because I actually don't know how the BMU is constructed.
I've already changed BMUs with no change
9Back to top Go down   Tail light problem Empty Re: Tail light problem on Fri Jan 25, 2019 5:23 am
Tail light Fixed!
From an old post from Inge K:
Check if you have power at the grey/blue wire at the connector for the
ignition switch (under the tank).
Yes: the problem is in the ignition switch.
No: the problem is in the light on/off switch, or the related wiring.
I had power at the grey/blue so looked into the ignition switch side.  The switch was passing power from the red to the grey but nothing on the grey at all at the connector. It was simply a bad/dirty connection in the connector plug from the switch to the loom. Working for now but will have to get the de-oxit on it.
10Back to top Go down   Tail light problem Empty Re: Tail light problem on Fri Jan 25, 2019 5:53 am
good find Al
surely the  headlight  park lights were not working also ?
ride well mate
