1Back to top Go down   Aftermarket clutch plate? Empty Aftermarket clutch plate? Mon Jan 28, 2019 9:58 pm
Has anyone here tried the lower priced Eyetalian clutch friction plates from Motobins?
OEMs are 75 pounds, these are only 44.
2Back to top Go down   Aftermarket clutch plate? Empty Re: Aftermarket clutch plate? Mon Jan 28, 2019 10:01 pm
No but; the shape, layout and securing of the friction bits is identical to the Eyetalian clutch plates I use on my Guzzis and they've never given any trouble.
3Back to top Go down   Aftermarket clutch plate? Empty Re: Aftermarket clutch plate? Mon Jan 28, 2019 10:02 pm
Yep, got one in my OZ-based RS. Been in there since about early 2011, plenty of kilometres on it. I got because I knew I wasn't gunna change the pressure plate(s) and it did slip ever so slightly at higher revs until it matched itself to their irregular surfaces. I was pleasantly surprised by the quality. It's all EU specs nowadays, I expect.
4Back to top Go down   Aftermarket clutch plate? Empty Re: Aftermarket clutch plate? Mon Jan 28, 2019 10:50 pm
brickrider2
brickrider2
Yes, there is one in my 1983 airhead.  I'd buy another.
1996 K1100LT
5Back to top Go down   Aftermarket clutch plate? Empty Re: Aftermarket clutch plate? Tue Jan 29, 2019 12:09 am
brickrider2 wrote:Yes, there is one in my 1983 airhead.  I'd buy another.
+1 in the K1100
6Back to top Go down   Aftermarket clutch plate? Empty Re: Aftermarket clutch plate? Tue Jan 29, 2019 1:03 am
yep …
not long after suffered gearbox input spline failure  (the splines within the clutch plate just looked over sized to me (still have the piece for reference )
more likely a heap of wet weather riding  washed the lubricant out of the splines ….but there you go
7Back to top Go down   Aftermarket clutch plate? Empty Re: Aftermarket clutch plate? Wed Jan 30, 2019 7:32 am
I bought Sachs for my K100RT. Much same price too.
Sachs make the plates for BMW.
Even better, BMW don't make clutch plates at all.
