1Back to top Go down   Rear main seal - I need some advice Empty Rear main seal - I need some advice Thu Jul 12, 2018 7:21 pm
Hello All
I need some advice
I brought a rear main seal from Motorbin  ( The BMW ) brand one   and it had the instruction on the site to soak in oil for two hours before installing.
long story short  - I stuffed up installing this seal and deformed it. so I ordered another one form Munich in Western Australia so i could get it before the weekend
The   ( BMW ) brand one from Munich states install dry  but it has exactly the same  part numbers
So  this is the first  difference  in install
I have contacted both wholesalers and they stand by their instructions.
I also have been reading different threads and 50 % state to stretch the seal first  over ( Pipe / Socket / Pill Bottle ) the others state don't  do this.
So  this is the second difference  in install
Then further reading state that the  oil lip needs to be towards the front of the engine  and others state that it rolls back on-itself to face the back of the bike
This seems strange to me and I might be reading it wrong or the the thread is incomplete  ??
Thank You in advance
matt the ones suggested to put over with a pill bottle are the thin Teflon types , and usually for the seal at the timing chain - hall sensor seal at the front of the engine   the profiled seal at the rear- clutch is a very different material ,
press the seal home dry
then lubricate liberally the seal lip and the clutch mount shaft whilst reassembling carefully .
good luck
- newer seals made with PTFE should be installed dry
- the seal membrane should curl back to face the front of the engine when the clutch is installed. Nothing you need to do to make this happen
- No need to stretch the seal (have never heard of this. References please)
- install the seal carefully. use a hammer and wooden block, hammering gently and measure often to ensure the seal is being driven evenly
- make sure the seal face sits 0.5mm proud of the casting face. Do not drive it fully home flush with the casting.
Thanks Guys
So the my RS developed a leak at via the breather hole in the bell housing  about 500 km after replacing the Rear Main Seal
So on the week end I started the second attempted, interesting it only took about 2 hours to get the gear box out and onto the work bench
compared with my first attempt
When lift the gear box onto the bench I can see a sheen of oil around the Gear Box  Input spline
and when looking at the clutch side of bell housing it seem free of oil
I know your meant to be able to smell the difference between the oils, but with my sense of smell I cant tell the difference.
it come in hand living with teenage boys and the wife cooking
Question
If the Rear main was leaking oil would it appear around the  Gear box Input shaft ?
I can see how  but a stupid question  is one not asked
In replacing  the gear box input shaft oil seal do you just pick it out and re-seat a new one in place  or is there additional work that should be done  ?
The rear main seal leak will usually show up as engine oil inside the housing but iy usually doesn't get on the clutch but if the big O-ring is leaking that will often get on the clutch and possibly the face of the transmission. If the front transmission seal is leaking it will get on the clutch and face of the transmission however transmission oil can get from the seal on the rear of the main input shaft leaking (behind the throw out bearing and runs down the pushrod).
Smell some transmission oil in the bottle and compare with engine oil. Unless your nose is missing then you will smell the difference.
Matt if you need a hand or a nose give me a yell. As per Rick if you have no sense of smell get one of the boys or the Boss to have a whiff.
Regards Martin
Well oiled up the bike
And gave it a short test
Seem like the piddel has been fixed
Need a longer run now to find the next one
good to hear Matt
hmm feel like a run to  get the banner and meet twb on Saturday ?
not sure of details yet ....
Saturday is a bad day for me
Boys sports and the like start earlier morning and don finish till 5pm
 Sunday is clear
yep remember that well matt
4 to pickup , one to hockey , 2 to rugby , then pickup the hockey then back to rugby
sunday  was rugby only ...but could be anywhere in the greater Brisbane area .usually home after lunch
later was 3 to rugby
...then drop off again ...home by 6pm
summer was far easier ...giggles
Hello all
Still trying to sort out the leak from the bell housing weep hole
So i took the gear box out again to day
Im getting really fast at it now
I removed the clutch pack and basket
When i undid the center nut oil weep out past the cener o ring
I was able to pick out the oring in one piece using a krone tool
Last time i had to cut it
Does this mean it was installed incorrectly ?
After removing the clutch basket i put the oring back on the shaft and noticed that its very loose / sloppy
Is this correct ? I cant see how it would work being so sloppy ?
Matt what days are you home, I can try and get over. Could you see where the oil was coming from.
14Back to top Go down   Rear main seal - I need some advice Empty Re: Rear main seal - I need some advice Sat Feb 09, 2019 11:56 pm
Hello All
I measured the old center oring which came out of my bike last night and seems sloppy on the shaft at 18.64mm
The new one measure 19.14mm and seems even more sloppy
Do these compress once you tighten the center nut ?
Or should I go and get another one from an o ring shop with a smaller diameter ?
Once again thanks for the input
I want to stop this leak
Also iI noticed that you can feel the joint between the bottom block and top block on one side is this normal ?
Matthew-Brisbane wrote:I measured the old center oring which came out of my bike last night and seems sloppy on the shaft at 18.64mm . . . The new one measure 19.14mm and seems even more sloppy . . .Do these compress once you tighten the center nut? . . . Also iI noticed that you can feel the joint between the bottom block and top block on one side is this normal ?
The stock O-ring has a 19mm inner diameter and a 4mm cross-section. What was the cross-section of your choices? They compress when tightened. The thrust washer beneath the nut also is called a compression ring in the parts fiches. Follow BMW's tightening guidelines.
It's normal to feel joint seams. There's just something attractive about them. Laughing
Both o rings have the 4mm cross section
Just inner diameter and outer diamter changes on both the orings
That I have
Just seems really sloppy on the shaft
Matthew-Brisbane wrote:Just seems really sloppy on the shaft
It's difficult for us humans to understand what appeals to an O-ring. Smile
Anyway, I'd opt for the genuine article with the correct dimensions—differences in aftermarket O-ring material might have an effect—and tighten the nut onto the compression ring according to BMW's guidelines. I'm just that unadventurous.
The old one came from motorbins
And the new ones from motor works
Will upload a photo tommrow showing the differences
19Back to top Go down   Rear main seal - I need some advice Empty Re: Rear main seal - I need some advice Sun Feb 10, 2019 11:45 pm
Rear main seal - I need some advice Img_1713
The bottom O ring came from Motorworks and the top one from Motorbins
As you can see there is a fair bit of difference in the internal diameter
20Back to top Go down   Rear main seal - I need some advice Empty Re: Rear main seal - I need some advice Mon Feb 11, 2019 12:19 am
The internal diameter should 18mm and thickness 4mm so the lower one is not right.
21Back to top Go down   Rear main seal - I need some advice Empty Re: Rear main seal - I need some advice Mon Feb 11, 2019 12:38 am
Thanks Rick
Determined to stop this leak
22Back to top Go down   Rear main seal - I need some advice Empty Re: Rear main seal - I need some advice Tue Feb 12, 2019 10:32 pm
Hello All
So I ordered a new Oring from a good supplier of parts in Aus  and also brought one from a local dealership
Now I have 4 different size Orings  and confused at which one the best to use
Does anyone know the exact  OD measurement of the shaft were  the Oring sitting in the clutch basket
if not will need to go and buy a set of bent leg calipers to get the measurement
23Back to top Go down   Rear main seal - I need some advice Empty Re: Rear main seal - I need some advice Tue Feb 12, 2019 11:38 pm
The OEM part is an o-ring with an i.d. of 19mm and a thickness of 4mm.
RicK G wrote:The internal diameter should 18mm and thickness 4mm so the lower one is not right.
Yeah I'll correct that, sorry for the bum steer I was running on memory Matt 19mm x 4mm
