lefthander
lefthander
I have a 1992 k75 standard with a low seat. Has anyone ever wired a BMW navigator 3 with the mounting cradle to their bike? Any pictures or help would be great. Thanks
prince
prince
I just installed a Nav IV as a second gps on my K1600.
I bought BMW repair connector pn 83300413586 to plug into the cradle wiring. I don't like cutting wires if I don't have to. I pulled the power from my PDM60 since it provides switched power.
Red is positive and black is negative.
See this post: https://advrider.com/f/threads/wiring-bmw-navigator-iv.565952/
I can report the Nav IV powers up perfectly. The best part is I can remove the Nav cradle and move it to my K100 when I want to because I bought a second repair connector for it.
Paul
1984 Honda V65 Magna
1985 BMW K100RT
2011 BMW K1600GTL (gone)
2018 BMW K1600GTL
prince
prince
Help wiring Navigator 3 to 92 k75 standard low seat Img_2014
Paul
1985 BMW K100RT
2018 BMW K1600GTL
@lefthander wrote:I have a 1992 k75. Has anyone ever wired a BMW navigator 3 with the mounting cradle to their bike? Any pictures or help would be great. Thanks
The Nav III was standard equipment about ten years ago. If you also have the base and the factory power plug you only have to find a suitable switched 12V and earth point. I have the Nav III unit on my K1200R and it plugs directly into the wiring loom up the front. My suggestion, for keeping the electrical portion of the installation tidy, is to determine the plug type of the Nav you have and obtain the other side of the plug with a length of loom from BMW. These images are what's available from BMW. They're readily available, though not always cheap, but will provide you with an easily removable plug that you wire in to the aforementioned power and ground points. Where and how you physically mount the unit and cradle is a custom affair. There was a bloke selling a metal 'shelf' that fit behind and across the RS windscreen. I have one in Australia, but have never fit it to the bike. A handlebar mount such as RAM or other might be preferable on a K75, but you don't specify which model 75 you have....recommend placing that info in your signature line for all to see at a glance.
Help wiring Navigator 3 to 92 k75 standard low seat Screen12
Help wiring Navigator 3 to 92 k75 standard low seat Screen13
HERE  is a link to the ETK page so you can access the part numbers of the plug you need.
1977 R75/7-R100 grey, '87 K100RS red, '93 K11-K12 aka 'Big Block' black, '96 K1100RS black, '98 K1200RS red, '09 K1300GT red, & 2013 R1200RT-Polizia black & white.
BobT
BobT
I am trying very hard to understand what the low seat has to do with a GPS?
lefthander
lefthander
Suggestion was made to describe the model k75 I have. Just giving all info on the bike.
@lefthander wrote:Suggestion was made to describe the model k75 I have. Just giving all info on the bike.
Putting your moto's model, year and unique features information in the Signature section of your Profile will have it showing up beneath every post you make. That will help inform readers and prospective respondents to your posts.
1995 K75 73,000 miles
Help wiring Navigator 3 to 92 k75 standard low seat Usa-lo10
8Back to top Go down   Help wiring Navigator 3 to 92 k75 standard low seat Empty K75 gps hookup on Mon Feb 18, 2019 7:24 pm
lefthander
lefthander
So I found the Nav 3 wiring harness that goes to the gps and the four button cradle.  Anyone happen to have the plug that it would plug into that gets wired to power from the bike?
1992 k75 standard low seat. (transforming into a K75T low seat). roundel
prince
prince
@lefthander wrote:So I found the Nav 3 wiring harness that goes to the gps and the four button cradle.  Anyone happen to have the plug that it would plug into that gets wired to power from the bike?
Post a picture of it or take a look at the pic TWB posted.
Paul
1985 BMW K100RT
2018 BMW K1600GTL
lefthander
lefthander
In the picture I need the 2 pole connector. It's #9 in the top picture
@lefthander wrote:In the picture I need the 2 pole connector. It's #9 in the top picture
BMW part number 83 30 0 402 344 @ US$27.30
prince
prince
09Repair plug, 2-pinNo. 610619183300402344 $27.30SI 75/2004
Paul
1985 BMW K100RT
2018 BMW K1600GTL
prince
prince
btw, BikeBandit sells that part for $15.31
Paul
1985 BMW K100RT
2018 BMW K1600GTL
lefthander
lefthander
Thanks for all the help. Once I get this plug I'd be greatful for help in wiring this up to my 1992 K75 standard.
prince
prince
@lefthander wrote:Thanks for all the help. Once I get this plug I'd be greatful for help in wiring this up to my 1992 K75 standard.
Generally, for BMW's red is positive and black is negative. The repair wire connector might have both wires as yellow (the one I used had all 3 wires yellow).
The Nav IV cradle I have has the wires coloured: red, black, yellow. It was easy to wire up. The Nav's seem to be polarity secure so if you get the polarity mixed up it will protect itself. But better safe than sorry.
Always use a fused power source. 3 amp is fine. You can use a regular automotive Bosch relay to make it a switched power (power to the gps only when the bike is turned on). I always get the trigger source from the tail light.
Paul
1985 BMW K100RT
2018 BMW K1600GTL
More specifically, ground or earth wires on German machines are typically brown.
prince
prince
@Two Wheels Better wrote:More specifically, ground or earth wires on German machines are typically brown.
Ah, yes....sorry ... North American convention is ground is black.
Paul
1985 BMW K100RT
2018 BMW K1600GTL
18Back to top Go down   Help wiring Navigator 3 to 92 k75 standard low seat Empty gps on Tue Feb 19, 2019 5:06 pm
lefthander
lefthander
Thanks Laitch, I believe my bike description is there now.
19Back to top Go down   Help wiring Navigator 3 to 92 k75 standard low seat Empty K75 gps hookup on Thu Feb 21, 2019 4:55 pm
lefthander
lefthander
I found a wiring harness that plugs into the gps and the 4 button cradle with the cigarette lighter power source on the dash of my 1992 k75 standard for my Navigator 3. It was on ebay, from China  and says used, with the name Garmin on it. Anyway, because I am electrically challenged to put it mildly I've decided to go this route. Once I get it and verify it works, anyone who would like to have the harness I was going to use can have it for the cost of shipping. If there is room in your budget to donate anything to this sites donation place then that would be great. Again, thanks to all for your help.
