1Back to top Go down   Blade LED and circuit breaker fuses. Empty Blade LED and circuit breaker fuses. on Wed Apr 03, 2019 1:10 am
I'm in the process of cleaning and replacing all my fuses with LED indicator fuses. In the process of doing this and I spotted these blade circuit breaker fuses with either an auto reset or manual reset. They are too large to go under the OEM cover but the manual reset could be useful for diagnostics either at home or on the side of the road. Has anybody tried these??
Regards Martin.Blade LED and circuit breaker fuses. Blade-10
2Back to top Go down   Blade LED and circuit breaker fuses. Empty Re: Blade LED and circuit breaker fuses. on Wed Apr 03, 2019 1:52 am
Yeah I carry a 10A and 20A breaker for that exact purpose and Bert had a thread on it about 18 months - 2 years ago.
3Back to top Go down   Blade LED and circuit breaker fuses. Empty Re: Blade LED and circuit breaker fuses. on Wed Apr 03, 2019 2:50 am
I've probably forgotten or missed it. Blade LED and circuit breaker fuses. 610153  While I was getting the fuses I found that Jaycar is stocking reusable cable ties. The sales person didn't even know about them, bought two mixed packs one for the bike and one for home. They do come in handy.
Link https://www.jaycar.com.au/releasable-cable-tie-pack/p/HP1217
Regards Martin
4Back to top Go down   Blade LED and circuit breaker fuses. Empty Re: Blade LED and circuit breaker fuses. on Thu Apr 04, 2019 11:28 pm
Like Rick G, I’ve been carrying them for a few years now for roadside testing if I blow a fuse (like melting the low heat resistor harness for the heated grips if used on low for extended periods).
5Back to top Go down   Blade LED and circuit breaker fuses. Empty Re: Blade LED and circuit breaker fuses. on Fri Apr 05, 2019 12:19 am
Have you guys tested these?  If you put 12V to one side and ground to the other does it blow?
6Back to top Go down   Blade LED and circuit breaker fuses. Empty Re: Blade LED and circuit breaker fuses. on Fri Apr 05, 2019 5:23 am
1. Interesting test on youtube for this fuse
https://www.youtube.com/watch?v=zzzS08A-GfY
I will be ordering some for on the road troubleshooting.
2. I only heard about the Led fuses on this forum (thanks Duck) and they proved very useful when troubleshooting a shorting headstock loom issue at K1Fest last year. ABS light and Temp light on at the same time on my k1 !!.
3. Gaz (or Duck) did you manage to repair the heated loom issue, I thought using a high wattage resistor might be an option ?
Blade LED and circuit breaker fuses. Ir-log10
   ;BMW; K100RS Style Black 1987 105K Km     ;BMW; K1 Black 1993 51K Km     ;BMW; K1100RS Red 1993 70k miles  ;BMW; K100 16V Black (ex ElectricMonk)  ;BMW;  K1100LT (Swiss) soon to be an RS
7Back to top Go down   Blade LED and circuit breaker fuses. Empty Re: Blade LED and circuit breaker fuses. on Fri Apr 05, 2019 6:52 am
Simon, in answer to (3) in my own case I went with the PWM solution giving me variable control and I'm sure I read up on it from Duck.
I did however assist a friend with setting up a set of BMW heated grips and we obtained a suitably rated resistor and connected it into the standard BMW circuitry in place of the orange resistive wire. We mounted the resistor behind the front fairing clear of any other wiring and where it got good airflow for cooling. In that case the switching and appearance remained exactly as per factory.
Blade LED and circuit breaker fuses. 2b7bea10
8Back to top Go down   Blade LED and circuit breaker fuses. Empty Re: Blade LED and circuit breaker fuses. on Fri Apr 05, 2019 10:53 am
I know of possible four solutions to avoiding the heated grip low setting issue:
1) Just cut the orange wire from the switch to disable it.
2) Swap in a load resistor for the factory resistive wire like Gaz did.
3) Use a simple generic flasher relay instead of the factory resistive wire. (This gives you full power half of the time instead of giving you half power all of the time but the net result is roughly the same and doesn't generate excess heat like a load resistor does.)
4) Use a PWM to get variable heated grips.
9Back to top Go down   Blade LED and circuit breaker fuses. Empty Re: Blade LED and circuit breaker fuses. on Fri Apr 05, 2019 12:02 pm
Thanks Duck some excellent solutions.
I hope you liked the fuse video  Laughing
10Back to top Go down   Blade LED and circuit breaker fuses. Empty Re: Blade LED and circuit breaker fuses. on Fri Apr 05, 2019 2:51 pm
