1Back to top Go down   Naughty K 100 rs 1984 model, Empty Naughty K 100 rs 1984 model, on Thu Apr 04, 2019 8:45 am
moriarti
moriarti
Hi all I have done most of the jobs suggested however ,I removed the 4 screws holding fuel cap in place and tried very hard to remove it STUCK SOLID ,short of a medium crew bar,any tips on this please. Until i get it off i cant change fuel filter etc ,The tank 18 ltr capacity not 22 as most manuals state, so 1 hase the tank shrunk with age?
2 are the 7 lte/4ltr warning lights calibrated for all sizes or what ,im stuffed on this one drunken drunkenMuch knee bending and groveling as usual payment for input Chatter :M:thanks
2Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, on Thu Apr 04, 2019 9:22 am
Open the cap 90 degrees. Then smack it sideways with your hand from one side or the other. If that doesn't work try something a little heavier like a rubber mallet.
3Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, on Thu Apr 04, 2019 3:30 pm
Its got a sticky gasket keeping it in place. I know its a sticky gasket because there's one in my shed.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now91,850 miles
1983 K100RS 0011175 Fricka 29,495 miles Damn K Pox
4Back to top Go down   Naughty K 100 rs 1984 model, Empty Naughty K 100 rs 1984 model, on Fri May 24, 2019 9:18 am
moriarti
moriarti
Hi to all,back on the road and HO BUGGER the cut out is still there.Now follow me if poss,low speed cut out ,pull the clutch in fast, engine revs cleanly.Is it possible that the gear position switch might be
the culprit,or am i missing something scratch
1984 k100 rs red/black VIN 0004449
5Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, on Fri May 24, 2019 9:24 am
The only thing the gear position switch does is feed the digital gear in the cluster and send power to the start button when in neutral. It has no impact on operation.
6Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, on Fri May 24, 2019 9:26 am
moriarti
moriarti
OK thats one more thing of the list study
7Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, on Fri May 24, 2019 9:29 am
I would be looking at the route of the clutch cable under the tankhaving an effect onan adjacent wire that possibly has a lose connection/connector or damaged......clutch switch only affects starting, same with gear position indicator switch.
The slight movement of the clutch cable may be 'fixing' the problem so go slowly at it, with gas tank off. It may even be affecting he fuel tank plug connector.
8Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, on Sat May 25, 2019 9:27 am
moriarti
moriarti
Thanks Olaf im on it like a rash,otherwise Mystic Meg will be getting a call lol!
