1Back to top Go down   Seized Clutch, help please Empty Seized Clutch, help please on Wed Apr 10, 2019 9:52 pm
chris_610
chris_610
Hi,
A mate has recently picked up a K100RT and has tasked me with getting it going for him.
At the moment, it doesnt quite start but has been sitting for a while, when I tried to start it yesterday, it fired a couple times but wouldn't get going, im fairly confident if I drain the old fuel out and put some new fuel in it, it should hopefully start.
If anyone has any pointers on easy fuel tank removal or how to drain the tank without removal that would be awesome!
The other major problem I can see with the bike is the clutch seems to be seized.
You cannot pull the hand clutch lever back more than approx 5mm.
I think it is seized inside the clutch housing, as when you try operate the hand lever you can see the clutch arm at the back of the gearbox trying to move but thats where it appears to be stopping.
Bike details
K100RT
Build date 03/1987
Frame No. 0093954 K100RT
Aus. Compliance plate no. 550402
Any help or ideas would be appreciated, im hoping to get to the bike in the next few hours to have a go at trying to get it ride-able again.
Thanks again!
Chris
2Back to top Go down   Seized Clutch, help please Empty Re: Seized Clutch, help please on Wed Apr 10, 2019 10:00 pm
kioolt
kioolt
K100RT had a side stand interlock on the clutch.  If you have the bike on the side stand it will be hard to pull the lever.  Check that first.
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
3Back to top Go down   Seized Clutch, help please Empty Re: Seized Clutch, help please on Wed Apr 10, 2019 10:03 pm
Hi Chris welKome to our Knuthaus.
The problem doesn't ring any bells as to a common problem and usually the clutch mechanism is fairly good, but and there are lots of buts.
Release the cable from the lower end, you should be able to get a lever in and under the arm to move it upward. If you get the cable off then try to move the arm and it should move freely but the roller needle bearings do sometimes seize. They have a hard life down there.
If the arm is free then remove the rubber boot and check out the throwout bearing.
Also check to make sure the adjuster bolt has not over ridden the throwout and jammed.
See the PM I have sent.
4Back to top Go down   Seized Clutch, help please Empty Re: Seized Clutch, help please on Wed Apr 10, 2019 10:48 pm
+1 on what Rick said. Early in my Bricks life in an effort to stop problems I fitted a grease nipple to the clutch arm. A squirt of grease occasionally will stop the ingress of water and road crap. You also need to lube the nipples at both ends and the wear surfaces and pivot on the clutch lever. Also check that the lever is not worn and rubbing on the cable.
Seized Clutch, help please Clutch17
Last edited by MartinW on Wed Apr 10, 2019 10:50 pm; edited 1 time in total (Reason for editing : Added Photo)
5Back to top Go down   Seized Clutch, help please Empty Re: Seized Clutch, help please on Thu Apr 11, 2019 12:06 am
chris_610
chris_610
@kioolt wrote:K100RT had a side stand interlock on the clutch.  If you have the bike on the side stand it will be hard to pull the lever.  Check that first.
Hmmm, after a little research on this particular stand/clutch device, I think I better check this one first as I didn't realise this bike had this kind of interlock device.
I'm hoping this will remedy the problem, fingers crossed!
Failing that I shall try all the other suggested remedies.
Thank you all so much for you input, it is hugely appreciated!
Ill keep you posted on my progress
6Back to top Go down   Seized Clutch, help please Empty Re: Seized Clutch, help please on Thu Apr 11, 2019 12:14 am
chris_610
chris_610
Seized Clutch, help please 20190410
Seized Clutch, help please 20190411
The beast!
7Back to top Go down   Seized Clutch, help please Empty Re: Seized Clutch, help please on Thu Apr 11, 2019 3:11 am
A siphon will remove most of the fuel from the tank to facilitate removing it from the bike.
8Back to top Go down   Seized Clutch, help please Empty Re: Seized Clutch, help please on Thu Apr 11, 2019 5:38 am
I am not sure it does, over here they were definitely on K100LT [my K100LT has it] but yes possible. On centre stand with side stand retracted should clear that one.
Also very likely is seized up bearings in the pivot arm.
But...from experience when I had a similar problem when I got the K100LT....cause was fraying on the cable as the gearbox end.
9Back to top Go down   Seized Clutch, help please Empty Re: Seized Clutch, help please on Thu Apr 11, 2019 7:58 am
It's not an interlock.  It's a side stand retractor.  When you pull in the clutch it retracts the side stand so that you don't inadvertently ride off with the side stand down which can be troublesome on left hand turns. You are correct in that it doesn't let you pull in the clutch when the bike is leaning on the side stand.
10Back to top Go down   Seized Clutch, help please Empty Re: Seized Clutch, help please on Thu Apr 11, 2019 8:06 am
Chris this is a mechanical thing and its on my K100LT. If side stand is down with bike weight on it you will not get clutch action and will behave exactly as you describe.
I did keep that lubed up on the K100LT and worked brilliantly but its very prone to corrosion related seizing in our climate.
11Back to top Go down   Seized Clutch, help please Empty Re: Seized Clutch, help please on Thu Apr 11, 2019 4:52 pm
Some Brickers have experienced broken cables or pulled off cable nipples caused by pulling in the clutch with the side stand down. The two times I have loaned out my cable to mates was for this reason. Both bikes were K75s's.
12Back to top Go down   Seized Clutch, help please Empty Re: Seized Clutch, help please on Thu Apr 11, 2019 9:37 pm
chris_610
chris_610
Ok so im at the bike now and it was just the side stand down preventing the clutch handle from being functional.
Once i kicked the stand up the clutch operates fine.
Thank you for all the suggestions Smile
Next to see if I can get it running!
13Back to top Go down   Seized Clutch, help please Empty Re: Seized Clutch, help please on Thu Apr 11, 2019 11:53 pm
If only all fixes were that easy.
14Back to top Go down   Seized Clutch, help please Empty Re: Seized Clutch, help please on Fri Apr 12, 2019 6:36 am
good to hear chris ///good luck with the start process
believe me ....don't even attempt it till your sure the battery is at a good charge ,,,  if in doubt put it on a tender - charger at least overnight
the starter relay can weld if you have a low charge , additionally  the good voltage of a recently charged battery helps electronics work its best
good luck !
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OSeized Clutch, help please Au-log10
15Back to top Go down   Seized Clutch, help please Empty Re: Seized Clutch, help please on Fri Apr 12, 2019 10:43 am
chris_610
chris_610
After draining the tank, putting some fresh fuel in and a new battery, the old bike started after not too much dramas.
My mate was pretty happy with the success, I was pretty happy with the minimal stuff arounds........... If only they were all like that! Very Happy
Thanks again everyone for the much appreciated input and advice, I would probably still be scratching my head over that clutch lever and side stand if it wasn't for the help.
Happy motorcycling  cheers cheers cheers
