GK100
GK100
Hi there...
Been looking and seems that everyone agrees with the 50/50mix from GD and Wurth3000.
Well, i went to try and get those... GD is gone... and Honda 60 was substituited for something very diferent (m77) that seems not to work well on the 50/50 mix...
So... the big question is: What are you using? Any good substitute??
(I tried to search the forum to see if this has been discussed but with no luck...)
Many thanks
Woodie
Woodie
I have made my own by using different combinations of greases - Honda M77, Belray assembly lube + Belray waterproof grease.  Castrol Molub-Alloy is available to you in Europe and now Beemer Boneyard  in the USA has something to replace Guard Dog.  Haven't tried it though.
1985 K100RT
52667
Castrol Molub-Alloy (used to be known as Castrol Optimol) is brilliant at the job. A 100ml tube will last for years. I do approximately 15,000 miles (24,000 Km) a year on my K100 and after 76,000 miles (121,000 Km) in my ownership the splines are showing no signs of wear.
Next time you're in Praia do Carvoerio say 'hello' from me. I love the place - no 'attractions', so no noisy kids running around and no night clubs, just good food and lots of wine. It's an utterly beautiful part of the Algarve and yes, I have been up to the distillery at Monchique! Very Happy
+1 Dai I've used Castrol Optimol and just switched to Castrol Molub-Alloy 165,000 K's.
@GK100 wrote:50/50mix from GD and Wurth3000.
Actually it's either GD OR a 50/50 mix of Honda Moly 60 and Wurth 3000.
The purpose of adding the Wurth 3000 to the Honda Moly 60 is to make it stickier so it stays around longer.
The Guard Dog stuff was already sticky so no need to add the Wurth. (Which I suspect is what Guard Dog may have used in their formulation.)
edmundf
edmundf
Spline lube is on my backlog to do - i have some of the Honda Moly to do the job. Hopefully it is as easy as it looks
@Dai wrote:Castrol Molub-Alloy (used to be known as Castrol Optimol) is brilliant at the job.
I've found several different Molub-Alloy product numbers, Dai. Which product number does your formula have?
1995 K75 73,000 miles
Spline Lube - No more Guard dog or Honda Moly 60... Usa-lo10
Good question. It says 'Optimol' on the tube.
I told you it lasts for years Spline Lube - No more Guard dog or Honda Moly 60... 44271 Spline Lube - No more Guard dog or Honda Moly 60... 44271 Spline Lube - No more Guard dog or Honda Moly 60... 44271 Spline Lube - No more Guard dog or Honda Moly 60... 44271
Oh - you wanted a sensible answer? Very Happy Motorworks are showing it as 'Molub-Alloy White Paste T'
https://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=40&Ct=YK&SbCt=BA_15_40_YK_10
BMW's latest spline lube is Molub Alloy paste TA BMW part no 18 21 9 062 599 and it is now silver grey. It took me quite a few phone calls to actually get the local BMW shop to part with a tube. Spline Lube - No more Guard dog or Honda Moly 60... 167893
My tube of Castrol Optimol (white in colour) is still going after many years also.
Some of us here in Oz have also used this product - not sure if it is available elsewhere.
Spline Lube - No more Guard dog or Honda Moly 60... Image17
Mind you, wear gloves when applying as it is black and stains hands very well.
Molylube GA50 You can get it at Blackwoods
yamaguzzi
yamaguzzi
Has anyone tried Loctite Moly Paste ?https://www.napaonline.com/en/p/NCB51048
PDF Of Spechs
@yamaguzzi wrote:Has anyone tried Loctite Moly Paste ?https://www.napaonline.com/en/p/NCB51048
PDF Of Spechs
Looks like good stuff
GF Wollongong
GF Wollongong
Has anyone tried "Long Term Grease"?
Local bearing shop sells Falk LTG $50 approx for 400g.
It is very thick and sticky - same or better than the white shite BMW sells in the little containers for splines.
https://www.ebay.com.au/itm/Motorex-102424-Long-Term-Grease-2000-400g-Cartridge/371926526386?epid=1538135781&hash=item56988c69b2:g:0vcAAOSwkhlc151K&frcectupt=true
Guy
yamaguzzi
yamaguzzi
PDF Of Spechs
I just bought the Loctite Moly Paste .It looks exactly like the Honda Moly and has 65% Moly in it .Will be using it on my 1988 K100 RS and my Moto Guzzi 850-T . They claim it is for applications such as spline lubrication .
volador
volador
What ever happened to the use of good ol' Staburags NBU 30 PTM ?
