1Back to top Go down   Woops filled up with an enathnol blend  Empty Woops filled up with an enathnol blend on Sun Apr 28, 2019 12:33 am
Hello guys
I stuff up and filledup with an enathnol blend fuel
If I syphon out as much fuel as i can and replace with the good stuff will this be ok ?
Do i need to get rid off every bit ?
Dont think the wife will let me go for another 300km ride to get rid of it
It wont hurt. I often put 50/50 E10 and 98 in for the first tank of a long ride it gets rid of any condensation out the exhaust.
Riding E5 and E10 95 in my K1100 here in Netherlands, still no problem.
Sure rund better with the pure 102, best I noticed that with my R1100RS.
Woops filled up with an enathnol blend  Eu-log10  K1100RS/LT - R1200RT - R1100RS (RIP) - Cagiva SST 350 Ala Verde
As they said - it won't be a problem as long as you don't let it stand too long.
These bio fuel blends aren't bad for the engine but they do have a cleaning effect and that displace dirt and can cause filters to clog. Unless your fuel system was particularly dirty, you are unlikely to have an issue with that. However, where you can get problems on older systems is with the rubber components which can breakdown with certain esters in the bio fuel. This is not an instant effect, so riding, diluting and using up will not have any serious consequences. Leaving the bike to stand for weeks on end...then you are headed into goo territory!
If the wife won't let you do a 300km ride to get rid of it, do some shorter rides and top up the tank with your normal gas when it gets to about half full. Ride, fill repeat.
Woops filled up with an enathnol blend  Uk-log10 Woops filled up with an enathnol blend  Sco-lo15 Woops filled up with an enathnol blend  Eu-log10
                              Paul  Woops filled up with an enathnol blend  905546712
Go for the 300Km ride and sod it!
Michael Sydney
Michael Sydney
@Matthew-Brisbane wrote:Hello guys
Sorry Mathew, it is absolutely essential that you go for a 300 km (+) ride asap to avoid a total destruction of your bike's fuel system. It might be good for you too.
Any reasonable partner would understand. Smile
Living in the past! K100 '83 and R65 '83.
I run E10 most of the time during the riding season when it can't lay in the tank for more than a week or so.  For the winter I switch to non-ethanol fuel a week or two before going into storage so the bike sits with pure (stabilized) gasoline in the system.
I have been doing that with all my engines for about 20 years now, and have had no ill effects on fuel systems or operation.  The critical thing is to get the E10 out before storing as it decomposes into some nasty stuff over long term idleness.
However, having said the above, your wife should recognize that a 300km ride at this time of year is critical to preventing near fatal damage to your engine caused by the fuel mixture.
Thanks Guys
Going for a ride next weekend   800Km  to Rick and Charlies
9Back to top Go down   Woops filled up with an enathnol blend  Empty Woops on Mon Apr 29, 2019 3:04 am
daveyson
daveyson
From worried about 300km to confident in 800 has got me worried about Murphy's law of inverse proportions, number 987, which states that the greater the distance,  the less likely that when you get back, the locks havn't been changed.
@Born Again Eccentric wrote:As they said - it won't be a problem as long as you don't let it stand too long.
If the wife won't let you do a 300km ride to get rid of it..........
Nuff said but my mammy told me it was rude to refer to people as 'it'
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now 96,650 miles
1983 K100RS 0011175 Fricka 29,495 miles Damn K Pox Its a Bat outta Hell
