1Back to top Go down   Cant get a VIN report on my '84 K100rs. Empty Cant get a VIN report on my '84 K100rs. on Mon Apr 29, 2019 3:42 pm
JDiggamus
JDiggamus
Hi all, so I have a 1984 K100rs and there are only 13 numbers on my VIN. I'm assuming this is because this bike was intended for the Europe market that year only. Does anyone know how I could access my VIN report? There is nothing in the US databases.
thanks!
1984 BMW K100RS
Los Angeles, CA
last 7 of VIN#0019268
;BMW;
Chocolate
Chocolate
Hello try this:
http://bimmer.work/
Cant get a VIN report on my '84 K100rs. 24535010
JDiggamus
JDiggamus
Thanks! no luck with that website. Got a bunch of pop up ads.
1984 BMW K100RS
Los Angeles, CA
;BMW;
Have a look at this web site
and here is your result
Cant get a VIN report on my '84 K100rs. 1984_k10
Also lookhere for parts for your bike.
Last edited by Gaz on Mon Apr 29, 2019 7:41 pm; edited 1 time in total (Reason for editing : Added parts info)
1990 K75 6427509; 1987 R80G/S PD 6292136; 2010 G650GS ZW13381;95 K1100LT 0232224
@JDiggamus wrote:Thanks! no luck with that website. Got a bunch of pop up ads.
Adblock is your friend. I've forgotten what it's like to be constantly bombarded with adverts for crap I'm not in the slightest bit interested in. Install it and get the peace you never knew you were missing! Cant get a VIN report on my '84 K100rs. 44271
https://adblockplus.org/
In amongst the popups, there is a space labelled VIN. Enter the 7 digits there.
There is also the part that is labelled "I am not a robot", known as a captcha. Click in the box, and if anything else comes up it will be asking you identify pictures containing a specific object. That doesn't always happen - depends on the whim, I think sometimes. Wink
Finally, click on Submit. Ignore everything else.
The advantage of this one is that it gives extra detail like fitted options, manufacture date, not just month/year, original colour . . .
1985 K100RT VIN 0028991 My original Very Happy (Historic rego)
1985 K100RT VIN 0029036 BOB the Blue Old Bike (Historic rego)
1990 K100LT VIN 0190452 Work in progress
1984 K100RT VIN 0023022 Work needing lots of progress
1986 K100RT VIN 0090542 Work needing lots and lots of progress
1993 K1100LT VIN 0183046 Work in progress
1993 K75S VIN 0213045 Newest toy, slightly non-original
@Gaz wrote:Have a look at this web site
This is interesting. My 84 K100RT is same as this and I have put over 50k miles on it, from 36k to almost 90k. It shoes engine code 0514
But my 'new' K100RS shows mostly the same data with date 1983/11. It has the engineering drain plugs on the cam cover.But it shows engine code 0513.
There is no way the engines are the same. As soon as I can I will have 88 take a ride on it but my view is the RS is most definitely a hotter engine as in camshafts. Its completely original [apart from brake lineand accessory upgrades] and has had fuel pump replaced and fuel system and injectors cleaned out and its got only petrol in the tank.
So, my question is anyone know the difference between the two engine codes when they changed from 0513 to 0514?
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now91,850 miles
1983 K100RS 0011175 Fricka 29,495 miles Damn K Pox
