1Back to top Go down   1994 K1100LT radiator fan Empty 1994 K1100LT radiator fan on Tue Apr 30, 2019 3:18 pm
mike d
I have a new fan assembly to replace the dead one in my 1994 K1100.
Searching on here, looking in the BMW K1100 workshop manual, and the Clymer, all say to drain and remove the radiator.
Is this the only way or is the an alternative work around?
Mike
2Back to top Go down   1994 K1100LT radiator fan Empty Re: 1994 K1100LT radiator fan on Tue Apr 30, 2019 3:28 pm
I don't believe there is.....did mine and had to do that.
While you have it off clean the temperature sensor too....its in behind the radiator....to drain loosen the hose at the water pump, don't open the drain plug.....
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
3Back to top Go down   1994 K1100LT radiator fan Empty Re: 1994 K1100LT radiator fan on Tue Apr 30, 2019 4:07 pm
Removing the radiator to replace the fan is an excellent time to clean the radiator inside and out with white distilled vinegar.
Lay the radiator in a shallow pan and pour two gallons of the vinegar over it and into it.  Let it soak overnight and rinse the fins from behind with a moderate stream of water.  Flush out the interior with a gallon of distilled water.
This will go a long way toward improving the cooling of your engine.
4Back to top Go down   1994 K1100LT radiator fan Empty Re: 1994 K1100LT radiator fan on Tue Apr 30, 2019 6:08 pm
mike d
Thanks for the replies. I suppose I knew all along that radiator removal was the best way, for the reasons pointed out re cleaning etc.
It'll be the same for the new rear suspension and fuel pump units that arrived from Motobins today, remove clean all around and replace.
Mike
5Back to top Go down   1994 K1100LT radiator fan Empty Re: 1994 K1100LT radiator fan on Tue Apr 30, 2019 6:38 pm
When refilling put the coolant volume required amount in first so you can top off with just di water.
6Back to top Go down   1994 K1100LT radiator fan Empty Re: 1994 K1100LT radiator fan on Wed May 01, 2019 3:40 am
7Back to top Go down   1994 K1100LT radiator fan Empty Re: 1994 K1100LT radiator fan on Wed May 01, 2019 8:53 am
mike d
The replacement fan assembly I got from Motorworks looks like the one in the top picture. It has a Spal fan on it.
One downside is that the metal mounting bracket is poorly finished as it has burrs on one of the mounting holes, plus some of the edges are sharp. I will de-burr before it goes on the bike.
I went to a Classic Bike show in the UK last Sunday expecting to see the guys from Motorworks as they normally have a stand there. They take orders on the day which are then shipped free of posting. Unfortunately no sign of them.
Mike
