K75rt
K75rt
Hi,
  I was thinking about installing a K75s bellypan on a k75rt to make the front more finished. Do you think it will fit? I like the s bellypan more than the rs because it covers the entire front engine.
Yes, it's been done before. But it won't just "bolt right on" because the K75RT uses a K100 radiator so the radiator hose doesn't go through the crank cover like it does on the other K75 models.
You probably also need to do some trimming down where the bottom of the fairing protects the rider's feet.
k75s Engine spoiler bellypan on a K75rt $_86
K75rt
K75rt
Nice. That’s the first pic I’ve seen of an RT with a bellypan.  Is that the rs belly pan or the s? It doesn’t look like it goes all the way up, but maybe the radiator hose is in the way?
