1Back to top Go down   BMW K75S  Empty BMW K75S Sat May 18, 2019 2:17 pm
Superfast
Superfast
Hi Guys
Im new to this forum system  Very Happy
Ive purchased a bmw k75s cafe racer style but the last couple of times ive riden the bike when ive pulled over after riding for an hour or so and switch off the engine the bike wont restart straight away..?? nothing happens at all no starter motor, no fuel pump, nothing..?? after leaving it about 10 minutes it restarts..??
just wondering if anyone as had a similar problem
thanks
2Back to top Go down   BMW K75S  Empty Re: BMW K75S Sat May 18, 2019 2:43 pm
Welcome!  Can't help, my bike is stock.
3Back to top Go down   BMW K75S  Empty Re: BMW K75S Sat May 18, 2019 2:55 pm
Sounds heat related. What kind of ignition switch does it have and where is it located?
4Back to top Go down   BMW K75S  Empty Re: BMW K75S Sat May 18, 2019 3:00 pm
Superfast
Superfast
Hi I'm not sure to be honest, I know it's not standard..sorry
5Back to top Go down   BMW K75S  Empty Re: BMW K75S Sat May 18, 2019 3:01 pm
Superfast
Superfast
It's located on the LHS near the coils.
6Back to top Go down   BMW K75S  Empty Re: BMW K75S Sat May 18, 2019 5:01 pm
Welcome Superfast Smile
BMW K75S  Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
7Back to top Go down   BMW K75S  Empty Re: BMW K75S Sat May 18, 2019 5:44 pm
How hot does the ignition switch get when running?  If nothing works on the bike when you try to restart and it's hot then it sounds like it might be an ignition switch issue. Can you use a heat gun or hair dryer with the heat off to cool the ignition switch down in order to troubleshoot?
8Back to top Go down   BMW K75S  Empty Re: BMW K75S Sat May 18, 2019 6:03 pm
Superfast
Superfast
Hi duck
Thanks for reply, think I've left some info out sorry....when I turn the key to the on position after switching off the speedo/tacho,lights & everything that should work works but when I try to start Nothing..??
9Back to top Go down   BMW K75S  Empty Re: BMW K75S Sat May 18, 2019 6:37 pm
Do you pull in the clutch when starting?
10Back to top Go down   BMW K75S  Empty Re: BMW K75S Sun May 19, 2019 3:08 am
Superfast
Superfast
Yeah the clutch as to be pulled to start..🤔
11Back to top Go down   BMW K75S  Empty Re: BMW K75S Mon May 20, 2019 2:25 am
Superfast
Superfast
Hi duck
I've solved the problem thanks to you 👍 it turns out that the plunger on the clutch switch was not closing the contact... I've linked out the cable for now untill I get a new switch...Whoop
12Back to top Go down   BMW K75S  Empty Re: BMW K75S Mon May 20, 2019 8:00 am
td5
td5
Welcome from WA, glad you got it fixed, great forum here, lots of advice to be had.
BMW K75S  K_engi10
1988 / K100RS
2013 / R1200GS
2015 / K1300R
2002 / R1100S BCR
13Back to top Go down   BMW K75S  Empty Re: BMW K75S Mon May 20, 2019 1:31 pm
On the original K bike wither pull in clutch OR be in neutral with neutral light on gives you a start.
That works fine and if the neutral light goes you still have the clutch switch until it goes.
When that fails on the 2v Ks the rear brake switch is the exact same part, borrow it and use it for the clutch switch replacement. When you then go to replace the brake switch its all accessible on right hand side under the side cover without removing or lifting the fuel tank. Choke switch is also the same part.
