1Back to top Go down   Hello from Nottingham Empty Hello from Nottingham on Sun May 19, 2019 6:13 pm
Thicklotto
Thicklotto
Just got a beauty. Problem is the mirror pod will not fit back on.
2Back to top Go down   Hello from Nottingham Empty Re: Hello from Nottingham on Sun May 19, 2019 7:11 pm
moriarti
moriarti
Hi if the springclips on the base plate are bent/damaged best to replace them (motoworks) can supply
dont forget to fit a LIFELINE to the mirror body to stop it from falling off completely,have fun Big thumb
1984 k100 rs red/black VIN  0004449
3Back to top Go down   Hello from Nottingham Empty Re: Hello from Nottingham on Wed May 22, 2019 12:55 am
Snod Blatter
Snod Blatter
Welcome from Leicester cheers
As said, tie the buggers on because you really don't want to be forking out for a replacement!
Others: 1.5 x Honda CBX250RS-E, '94 CB250, '95 TRX850, '16 Z250SL
4Back to top Go down   Hello from Nottingham Empty Hello from Nottingham on Wed May 22, 2019 11:34 am
Thicklotto
Thicklotto
Hi, Thanks for the heads up. Anyone ever changed the internal mirror pod clips?
They don't look easy.
5Back to top Go down   Hello from Nottingham Empty Re: Hello from Nottingham on Tue May 28, 2019 5:35 pm
td5
td5
I'd give them a good squeeze first before I tried renewing, and as people have said install a tether
Hello from Nottingham K_engi10
1988 / K100RS
2013 / R1200GS
2015 / K1300R
