1Back to top Go down   Fault with indecators  Empty Fault with indecators on Tue May 28, 2019 4:58 am
residentalien
residentalien
I removed the front indicators to fit a headlight fairing , all wires went back as they was .
Now the right indicator works as it should , but when I turn the left ones on at the switch all 4 work at the same time , like hazard lights .
I have read all the problems in the past , and tried all there suggestions ,
Relay fuses all work fine
I did connect a wire from the battery to each side on the relay box , and just the side I had the wire come on , I thought maybe a left wire may have touched a right , to make all 4 work at the same time
Only thing I have not pulled yet is the starter motor , bike has been sat for years , but all worked ok , till I took the indicators off     Rolling Eyes
2Back to top Go down   Fault with indecators  Empty Re: Fault with indecators on Tue May 28, 2019 5:11 am
Swap out the indicator relay.
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
3Back to top Go down   Fault with indecators  Empty Re: Fault with indecators on Tue May 28, 2019 1:05 pm
As Olaf says. They're not foolproof; fortunately they come up cheap enough on ebay.
4Back to top Go down   Fault with indecators  Empty Re: Fault with indecators on Tue Jun 04, 2019 1:29 pm
residentalien
residentalien
It was the big green relay !
