Heresy23
Heresy23
So while working on my engine I noticed this taped up wire end...is it a accessory plug in (like heated suits etc...)? Ipmy first k bike so I’m learning...i know my battery tender is in the other side of the bike Accessories plug? Need help identifying  Da7b6610
Accessories plug? Need help identifying  399b5c10
brickrider2
brickrider2
It's always a good idea to identify the motorcycle you are working on.  Smile
1996 K1100LT
@brickrider2 wrote:It's always a good idea to identify the motorcycle you are working on.  Smile
Excellent idea!  Take a few minutes to put your bike's model and year in the signature line.  It really helps us identify what we are commenting on when giving assistance and troubleshooting tips.
The connector you are holding looks like it is the high altitude plug.  There is a matching connector with a short loop of wire that you plug in when riding above 4000 feet of altitude.  It tells the Jetronic to lean out the fuel mix to compensate for the thinner air at high altitudes.
The only time I use mine is when I'm out West in the mountains.  I have forgotten to plug in at 6-7,000 feet and left it in down to almost sea level and honestly haven't noticed any ill effects on the performance of my K75RT.  I suspect it's more of a clean air function to meet EPA requirements than anything to improve performance.
The biggest difference I've noticed without the altitude plug is that the bike starts to idle like crap when you get up above 8,000 feet and will die if you try to idle at 10,000 feet.
Heresy23
Heresy23
Thanks.!!i live at a altitude of around 2500 ft so no worries on that note
Oh and it’s a 85 K100RT ...😃
@Heresy23 wrote:Oh and it’s a 85 K100RT ...😃
Click on the Signature tab at the top of the page then put that information in your signature so it will show up as a reference below every post you make from now until the end of the world, as Point-Seven-five suggests.
1995 K75T 73,000 miles
Accessories plug? Need help identifying  Usa-lo10
Heresy23
Heresy23
Ok let’s see , think I got it now ..
85’k100 RT 73k
Heresy23
Heresy23
I put the miles in too , good idea ....I always got lots of questions !!
85’k100 RT 73k
