1Back to top Go down   Help choke light brake lights Empty Help choke light brake lights on Sun Jun 09, 2019 7:52 pm
Alistair1977
Alistair1977
My k100 has developed a fault and cant rectify it when u press front brake light choke warning light comes on. And when u put choke on front brake light comes on. Yes I've tried swapping wires can anyone help please
2Back to top Go down   Help choke light brake lights Empty Re: Help choke light brake lights on Sun Jun 09, 2019 9:38 pm
Go back and check the connections again.  The two switches have the same connectors and you have them reversed.
3Back to top Go down   Help choke light brake lights Empty Re: Help choke light brake lights on Mon Jun 10, 2019 5:27 am
Alistair1977
Alistair1977
I have already swapped them round still does the same
4Back to top Go down   Help choke light brake lights Empty Re: Help choke light brake lights on Mon Jun 10, 2019 1:09 pm
So you are saying that regardless of where the front brake switch is plugged into the wiring harness, it always lights up the choke indicator light, and no matter where you connect the choke switch it always lights the brake light.
Is that correct?
5Back to top Go down   Help choke light brake lights Empty Re: Help choke light brake lights on Mon Jun 10, 2019 6:35 pm
Alistair1977
Alistair1977
Yes that's right and I'm totally baffled as everything was working perfect till Friday checked wiring g diagram only thing I can think off is bulb monitoring unit how do I test as I was thinking if its buggeted maybe that's the problem
6Back to top Go down   Help choke light brake lights Empty Re: Help choke light brake lights on Mon Jun 10, 2019 6:58 pm
I have no idea how the wires in the wiring harness can change where they go when you change the switch you plug into a connector.
Not knowing the year of your bike we can't refer to the correct wiring diagram.  The brake switch is connected to the Bulb Monitor Unit,  but the choke switch isn't.
Has your bike been modified into a cafe racer?
7Back to top Go down   Help choke light brake lights Empty Re: Help choke light brake lights on Mon Jun 10, 2019 7:58 pm
Alistair1977 has an '83 K100RT according to his profile.
The choke indicator on the dash has absolutely no connection to the BMU.  As Point75 pointed out, the harness wiring can't suddenly change function ... unless it has developed a fault.  Have a look around to see if any wires are abrading against the frame or insulation looking disturbed.
8Back to top Go down   Help choke light brake lights Empty Re: Help choke light brake lights on Mon Jun 10, 2019 9:03 pm
@robmack wrote:The choke indicator on the dash has absolutely no connection to the BMU.
Nor to the switchgear since the switch for the choke indicator is on the back of the throttle bodies and goes straight to the cluster.
9Back to top Go down   Help choke light brake lights Empty Re: Help choke light brake lights on Mon Jun 10, 2019 9:13 pm
This is truly bizarre!
What happens if only the choke switch is plugged in and the brake switch is not?  Try the choke switch in both of the harness connectors.  One of them has to light up the choke light in the cluster.  Then plug the front brake switch into the other connector.
I realize it can be confusing because both switches are the same, with the same connector that can connect in several places in the harness.
10Back to top Go down   Help choke light brake lights Empty Re: Help choke light brake lights on Mon Jun 10, 2019 10:33 pm
Connector for the choke light has Violet/White and Brown wires.
Front brake switch has Green/Red and Green/Black wires.
11Back to top Go down   Help choke light brake lights Empty Re: Help choke light brake lights on Tue Jun 11, 2019 3:50 am
chris846
chris846
"And when u put choke on front brake light comes on."
What's the 'front brake light'?
The Longest Lunch
12Back to top Go down   Help choke light brake lights Empty Re: Help choke light brake lights on Sat Jun 22, 2019 9:40 am
mike d
Did you do anything to the bike on the Friday, or since the last time you rode it before the Friday?
Mike
13Back to top Go down   Help choke light brake lights Empty Re: Help choke light brake lights on Mon Jun 24, 2019 4:33 pm
The rear brake light and the clutch switch also have the same connections, you have 4 of these switches, all identical and definitely got something missed up.
Choke light.
Clutch switch
Rear brake switch
Front brake switch.
All identical and interchangeable
The brake light is operated by either of front or rear brake. Your red triangle light will not go out unless both front and rear brake switches are correct. However start bike without touching either choke or clutch and then touch both front and rear brakes. If the triangle remains on then one or both brake switches are not plugged in correctly [or may be faulty]. Then pull clutch, if the triangle light goes out its telling you the clutch is connected to one of the brake connections. Likewise try the choke.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now 96,650 miles
1983 K100RS 0011175 Fricka 29,495 miles Damn K Pox Its a Bat outta Hell
