1Back to top Go down   Steering Damper Empty Steering Damper on Wed Jun 12, 2019 6:57 pm
stevenh
stevenh
My k100lt Trike could do with a steering damper. Has anyone fitted one to a K100. Any info and Pics would be great.
Steve
2Back to top Go down   Steering Damper Empty Re: Steering Damper on Thu Jun 13, 2019 12:03 am
If you swap in a front end from a K100RS4V, K1 or K1100RS then that has mounts for a steering damper. However, it's a rather major endeavor since you need to swap everything including brake master, lines and calipers as well as wheel, forks, fork trees etcetera. On the plus side you end up with better forks and much better front brakes.
3Back to top Go down   Steering Damper Empty Re: Steering Damper on Thu Jun 13, 2019 5:26 am
Some K75's came with an integral damper in the steering head. Should be something you could order from Motobins etc. Worth considering
4Back to top Go down   Steering Damper Empty Re: Steering Damper on Thu Jun 13, 2019 5:29 am
stevenh
stevenh
@K75cster wrote:Some K75's came with an integral damper in the steering head. Should be something you could order from Motobins etc. Worth considering
Cheers I'll look into it
Steve
5Back to top Go down   Steering Damper Empty Re: Steering Damper on Thu Jun 13, 2019 7:41 am
It's called a Fluidbloc.
6Back to top Go down   Steering Damper Empty Re: Steering Damper on Thu Jun 13, 2019 11:24 am
volador
volador
FluidBloc Damper doesn't appear on the Max Parts Fiche as a replacement part
https://shop.maxbmw.com/fiche/PartsFiche.aspx
Classic Chris Harris, Good Day
1984 K100RS 1991 K100RS
7Back to top Go down   Steering Damper Empty Re: Steering Damper on Thu Jun 13, 2019 11:55 am
Item 2
https://www.realoem.com/bmw/enUS/showparts?id=0561-EUR---K569-BMW-K%2075%2084%20(0561)&diagId=31_0387
There's also a couple of pointy bolts in the steering head to keep it in place - Item 3
