1Back to top Go down   Another BEP 3.0 wiring noob question Empty Another BEP 3.0 wiring noob question on Mon Jun 24, 2019 5:10 am
George_Pap
George_Pap
I want to connect my Bep 3.0 + Koso TNT 04 to my BMW K100 1985
One basic - maybe dumb - question but my skills on electronics are below average.
Do i need to power the BEP 3 directly from Battery (+12V) or not? I cannot understand that clearly from the diagrams and googling. Simple logic says that the bep gets power from the two intstrument cluster sockets as the original cluster was. Or not?  Sad Sad
If so do i need to use a fuse between the connection from battery to bep?  Amps?
thank you.
K100RT (Early 1985 -nonABS)
2Back to top Go down   Another BEP 3.0 wiring noob question Empty Re: Another BEP 3.0 wiring noob question on Mon Jun 24, 2019 12:26 pm
The BEP 3.0 will obtain all of its required power through the OEM connector. There is no need for you to provision any additional power sources for that box. The pins labelled BAT and SWP are power OUTPUTS that go to your TNT-04.
3Back to top Go down   Another BEP 3.0 wiring noob question Empty Re: Another BEP 3.0 wiring noob question on Tue Jun 25, 2019 5:25 am
George_Pap
George_Pap
@robmack wrote:The BEP 3.0 will obtain all of its required power through the OEM connector.  There is no need for you to provision any additional power sources for that box.  The pins labelled BAT and SWP are power OUTPUTS that go to your TNT-04.
Thank you Robert.
Yesterday, after following your advise i did the initial test connection.
I have connected BAT and SWP plus the Ground from Koso to Ground output of the BEP. Power on and everything worked fine. Now moving to the rest of the connections.
Thanks again
