1Back to top Go down   Change odometer mileage Empty Change odometer mileage on Sat Jul 20, 2019 2:15 pm
I just put this page up: http://bit.ly/kodochange
Once you have the guts out of the cluster, insert a small regular(flat) screwdriver in between the digit wheels and rotate it clockwise. While doing this you need to make enough of a gap between the two wheels for their little cogs to disconnect. The digit on the left side of the screwdriver will increase by one each time you do this.
Start at the second from the right (tens) digit and move to the left since each time you spin a number past 9 the number to the left of it will increase.
Example:
Change odometer mileage Odocha1
If you care about the rightmost digit you can spin that using Karumba or just put the bike on the center stand, put it in gear and run the bike.  (Of course if you spin it past 9 then the tens digit will increase by one so plan ahead.)
2Back to top Go down   Change odometer mileage Empty Re: Change odometer mileage on Wed Oct 23, 2019 7:19 pm
schrocketeer
schrocketeer
Here's some photos that may help you understand what's inside the odometer, so you can know what is being pushed around. Once I had taken the speedometer side of the cluster loose, removing the trip meter made it a little easier to spin the different mileage "wheels" (ones, tens, hundreds, et al).
Change odometer mileage Img_2012
Change odometer mileage Img_2013
Change odometer mileage Img_2014
Ken
85 K100RT
91 XR250
97 XR100
70 CT70
06 YFM400
Past Bikes:
95 VLX600
86 TRX250
02 GZ250
83 Z50R
78 ATC90
86 XR250
79 XR500
72 AT1
75 YZ360
78 DT400
75 DT125
73 Trail 70
Dad's bikes I rode in high school
69 CL175K3 Scrambler
71 R5-B (RD350 predecessor)
