1Back to top Go down   Fake Neutral Gear Empty Fake Neutral Gear on Sat Jul 27, 2019 3:58 am
KamilJ
KamilJ
Hey guys!
I keep on having a problem while downshifting, usually from 4th-3rd, but also upshifting. I am new to bikes in general so it hurts me, even more, when I hear my clutch cranking while trying to put it in gear because as far I know and I feel it is in a good shape so I feel like I am destroying it... and most of all i feel in danger while driving fast and it happens. When i shift the pedal feels sharp and well lubricated. like a good maintenance gun. I recently changed my clutch cable but I had the same problem before. I do all the maintenance myself so feels even worse as this is the only problem I have. also happens while upshifting to the second gear but this one might be my lazy footwork.
First thought was that it's simply an old bike so the amount of slack for the new riders is short. I just have to do it the right way. So I figured the number of revs might be not correct. as I might still not be used to motorcycle engine - in a car, it's "2200" or somewhere right above 3000 when having fun. So I read on a forum the guys ride between 5k-7k and that's what the engine likes. I am trying to figure out the final drive ratio and simply on what revs to change gears upwards. I usually keep 1st and 2nd on 3k and then 3rd to 3-5k up to 80kmh.
the question is silly but I have no one on a K bike around: how do you shift? what revs?
I do rev-matching while downshifting. do you?
or it might not be the case at all?
thanks!
Worship
2Back to top Go down   Fake Neutral Gear Empty Re: Fake Neutral Gear on Sat Jul 27, 2019 6:50 am
moriarti
moriarti
Hi first things first,please enter the bike details including VIN number/mileage on the signature strip this will enable the brains
on the forum to give accurate advice.Have you set the clutch cable correctly?? if not all sorts of problems will occur.Should you have local contact with experienced riders ask if they can
help out.Hopefully its rider error and not the clutch splines that need servicing  Rolling Eyes cheers
1984 k100 rs red/black VIN  0004449
3Back to top Go down   Fake Neutral Gear Empty Re: Fake Neutral Gear on Sat Jul 27, 2019 8:00 am
These are symptoms that often indicate a maladjusted clutch or the need for a transmission input shaft spline lube, as moriarti has indicated. Determine if there is any play in the shifter, too. Tell us here how long you've had the moto, how many miles are on it and how many miles you've logged on it.
You're likely to be able to repair this yourself.
1995 K75T 73,000 miles
Fake Neutral Gear Usa-lo10
4Back to top Go down   Fake Neutral Gear Empty Re: Fake Neutral Gear on Sat Jul 27, 2019 8:03 am
KamilJ
KamilJ
0103584K75S
86' K75S,
all with the book - 7,5 cm down and 2-3mm free play. 1510mm long. also, I changed the clutch handle with it.
it has 150k on it. i've put about 1k, it's my first season.
It's been maintained for 90k in Switzerland and then in Poland for the rest.
it is softer than previously I have to admit. but when pulled and on gear, I do not feel it's dragging (the cable does not feel too loose so the clutch touches the plates)
I did not check the gearbox oil yet! neither I had a chance to look at the shaft spine. and i will check on the free play on the shifter then! i only though it's often a problem as I went through some google search and "fake neutral" indicated this problem with poor shifting. i was wondering if there is an opinion that the bike isn't easy to handle for the begginers.
i will go through mechanics and write you in the evening. thanks a lot!
5Back to top Go down   Fake Neutral Gear Empty Re: Fake Neutral Gear on Sat Jul 27, 2019 8:16 am
You need to be very positive with the shifts, short shifts work OK on the Japanese bikes but the Getrag gearboxes don't take well to lazy shifts. Also as said the missed shifts can be a result of dry splines on the clutch shaft.
6Back to top Go down   Fake Neutral Gear Empty Re: Fake Neutral Gear on Sat Jul 27, 2019 4:16 pm
Woodie
Woodie
Definitely check your gearbox oil level.  I checked mine recently and had to add about 100 ml or so (there was no measuring involved).  Not much but I think it has made a bit of a difference in shifting.  I usually shift at about 4k rpm's when going up through the gears and always blip the throttle when down shifting -  a small blip if I'm slowing down slowly and heavier if I'm engine braking.  Rick is spot on about lazy shifts and I believe Robmack has previously described the feel of the early Getrag transmissions as 'tractor like'.  Bring everything up to spec - fluids, adjustments, etc. and then see where you are at.
1985 K100RT
52667
7Back to top Go down   Fake Neutral Gear Empty Re: Fake Neutral Gear on Sat Jul 27, 2019 7:03 pm
As noted above, false neutrals from 4->3 and 3->2 are usually a symptom of the need for a clutch spline lube.
Rick also has a point in that K bikes need to be shifted with authority.  You shouldn't be stomping on the shift lever though.
8Back to top Go down   Fake Neutral Gear Empty Re: Fake Neutral Gear on Sat Jul 27, 2019 7:17 pm
GF Wollongong
GF Wollongong
Do follow all of the advice so far...
I remember reading an article where the (female if I am correct) went to great lengths describing the benefits of applying (a little) pressure to gear selector pedal before pulling the clutch and going ahead with the gear change (ie. full pressure and movement).
Also, in an English classic bikes magazine, the happy owner of a R75 described the gearbox as "agricultural".
I occasionally get false neutrals between 4 and 5 - I can only blame myself for a half hearted effort on the pedal.
GF
9Back to top Go down   Fake Neutral Gear Empty Fake neutral on Sat Jul 27, 2019 7:52 pm
daveyson
daveyson
Hi
Service your bike then ride. You're new to riding so in six months it will be better, before long you'll be doing this on auto pilot. Different tips work for different people and different bikes. Try changing at 3000rpm and a few others. Don't let the revs drop.  Try quick changes,  slow changes. Try with the clutch lever just half in. Try feeling the gear leaver in, instead of force,  but with pressure,  I know,  that's an oxymoron. The first BMW I rode had no problem at all, but I still get false with mine now sometimes, I don't care I just have a second go at it. Try different boots.
Last edited by daveyson on Sat Jul 27, 2019 8:02 pm; edited 1 time in total (Reason for editing : Boots.)
10Back to top Go down   Fake Neutral Gear Empty Re: Fake Neutral Gear on Sun Jul 28, 2019 1:56 pm
Poupy
Poupy
As stated by many before, use the pedal to its full extent.
Also, and nobody apparently told it yet, when you change your gearbox oil, disobey the instruction manual and use some 75w140. It makes a hell of a difference on those bmw rough gearboxes.
11Back to top Go down   Fake Neutral Gear Empty Re: Fake Neutral Gear on Sun Jul 28, 2019 2:09 pm
It's a hit'n'miss gearbox, a strong foot will help Smile
Fake Neutral Gear Eu-log10  K1100RS/LT - R1200RT - R1100RS (RIP) - Cagiva SST 350 Ala Verde
12Back to top Go down   Fake Neutral Gear Empty Re: Fake Neutral Gear on Sun Jul 28, 2019 2:10 pm
@Poupy wrote:As stated by many before, use the pedal to its full extent.
And moly gear oil additive.  It's takes a few hundred miles to work in but it makes a noticeable difference in smoothing out the shifting.
13Back to top Go down   Fake Neutral Gear Empty Re: Fake Neutral Gear on Sun Jul 28, 2019 2:53 pm
A rounded tablespoon of 1.5 micron Molybdenum Disulfide powder in the gearbox oil will make it shift like a rice burner.
14Back to top Go down   Fake Neutral Gear Empty Re: Fake Neutral Gear on Sun Jul 28, 2019 3:13 pm
I use half a tube of this stuff:
Fake Neutral Gear 31ijmc0nmSL._SX466_
