1Back to top Go down   Finally found it Empty Finally found it on Tue Aug 06, 2019 11:15 pm
Finally found a bottle of blinker fluid....not sure whether it does 4 valve bikes though. Apparently you can get a dvd (shows how old it is) to help with the process of draining and putting in the fresh stuff.
Finally found it Img_2523
2Back to top Go down   Finally found it Empty Finally found it on Wed Aug 07, 2019 12:31 am
There there Stanley
take your meds and go back to the couch.
I  think life is getting too easy for you if you have time to spot that.
3Back to top Go down   Finally found it Empty Re: Finally found it on Wed Aug 07, 2019 5:04 am
Bob, I have researched it a bit further....no good with led blinkers.
4Back to top Go down   Finally found it Empty Re: Finally found it on Wed Aug 07, 2019 5:16 am
Oh I thought that everybody knew that old stuff didn't work with the new fangled LED bulbs.
5Back to top Go down   Finally found it Empty Re: Finally found it on Wed Aug 07, 2019 8:52 am
I ordered it in England, bargain price.
Should have known better....
When I hit the left button to go left, the right blinker goes on. Right gives the left blinker.
Had to drain the whole system and clean it before fill it with right side blinkerfluid.
Finally found it Eu-log10  K1100RS/LT - R1200RT - R1100RS (RIP) - Cagiva SST 350 Ala Verde
6Back to top Go down   Finally found it Empty Re: Finally found it on Wed Aug 07, 2019 9:33 am
@Arlina wrote:I ordered it in England, bargain price.
K bikes need to have the silicate free one.....well known issue.
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
7Back to top Go down   Finally found it Empty Re: Finally found it on Wed Aug 07, 2019 10:15 am
@RicK G wrote:Oh I thought that everybody knew that old stuff didn't work with the new fangled LED bulbs.
This is the stuff you need for LEDs. This grade is only for right hand drive countries in the northern hemisphere, so perfect for US, Canada and mainland Europe (and Ireland on the third Sunday of the month).
Finally found it Blink10
In the UK and other northern left hand drive countries the ID-10T grade is no good and you need to specify grade 1 EE-J1T. They are not interchangeable as Arlina found out. To make matters more complicated, if you live in the southern hemisphere, then you must ensure that you buy the proper phased fluid for use down there. DR-0NG 0 is the recommended grade for left hand drive countries in places like Australia. However, when i was down there last time, I noticed that it was extremely expensive - a cheaper substitute is to buy northern blinker fluid for the opposite hand drive - the American stuff (only $9.99 plus shipping and handling) is perfect for use down under as the reverse side of the road and the orientation inversion combine nicely together to make left blink left and right blink right.
Caution: Flash sequence is different when using ID-10T rather than DR-0NG 0. ID-10T normally gives an output of on-off-on-off etc. but if used in southern hemisphere left hand drive countries, you will note the flash sequence is reversed to off-on-off-on etc. This is not normally a problem and many don't even notice the irregularity.
Last edited by Born Again Eccentric on Wed Aug 07, 2019 10:34 am; edited 1 time in total (Reason for editing : Flash sequence clarification)
Finally found it Uk-log10 Finally found it Sco-lo15Finally found it Eu-log10
                              Paul  Finally found it 905546712
8Back to top Go down   Finally found it Empty Re: Finally found it on Wed Aug 07, 2019 10:56 am
The UK one at the moment is not recommended due to this Brexit stuff in it.
The left hand and right hand don't know what they are doing and you could be all over the place.
9Back to top Go down   Finally found it Empty Re: Finally found it on Wed Aug 07, 2019 8:57 pm
A friend of mine ordered it from a guy in Washington.
Blinkers didn't work, but the brakelight stays on till the battery is down.
Watch out for cans with a logo of Donald Duck blowing a trumpet !
10Back to top Go down   Finally found it Empty Re: Finally found it on Wed Aug 07, 2019 10:32 pm
Appreciate all the comments from other countries and members. Does anyone out there know of how long the fluid will last? 80,000 blinks or a time limit...like perhaps every 2 years? In my area I tend to do more left turns than right....will the turn switch wear out faster?
Some products promise many things but deliver little. We should consider a multinational trial of this product with periodical updates.Not sure of cost..tariffs on Chinese made fluid by the US and the UK may not being able to access the product from EU countries.
11Back to top Go down   Finally found it Empty Re: Finally found it on Wed Aug 07, 2019 11:11 pm
Your living in the past. Use the GPS on your iPhone 11 and link it to your Brick, then put in your route and it will flash your indicators automatically when you come to a corner. You can then remove your flasher relay and save weight. There is an update available shortly that will also operate your stop and tail lights when the phone senses you're braking or night has fallen. More features to follow.
Regards Martin
12Back to top Go down   Finally found it Empty Re: Finally found it on Thu Aug 08, 2019 2:59 am
daveyson
daveyson
@Stan wrote:Appreciate all the comments from other countries and members. Does anyone out there know of how long the fluid will last? 80,000 blinks or a time limit...like perhaps every 2 years?
Yes, every two years, but more often in dusty environments.
13Back to top Go down   Finally found it Empty Re: Finally found it on Thu Aug 08, 2019 7:18 am
We've been using this compound to restore Christmas tree and advertising sign lights for a few years. Dilute strength to obtain desired rate of blink. Wear eye protection. One of our workers learned that the hard way. Blinky is still one of our ablest employees though and a skilled mentor.
1995 K75 73,000 miles
Finally found it Usa-lo10
14Back to top Go down   Finally found it Empty Re: Finally found it on Thu Aug 08, 2019 7:53 am
Just found out it works with IPL devices too, need 2 cans in serial to get a higher blinkrate.
3 cans is too much, the skin will burn.
Finally found it 64e5daeb2a4434f17541bd4a9d629659
15Back to top Go down   Finally found it Empty Re: Finally found it on Fri Aug 09, 2019 10:35 am
I'm feeling a bit sad, I checked my blinkers and none of them have refiller caps? What do I do now??
16Back to top Go down   Finally found it Empty Re: Finally found it on Fri Aug 09, 2019 12:41 pm
moriarti
moriarti
Your K is for  the Middle East market,therefore you need to adopt the following method.Place the container in the  inverted position as near as possible to the Flasher relay and OSMOSIS will ensure the correct dosage study
1984 k100 rs red/black VIN  0004449
17Back to top Go down   Finally found it Empty Re: Finally found it on Fri Aug 09, 2019 3:18 pm
1. My rear indicators have drain holes in them and I find it very expensive keeping them topped up, is it safe to plug this hole ?
2. I frequently cross the Ireland / Northern Ireland border so with Brexit coming should I be using the British or European version ?
Finally found it Ir-log10
   ;BMW; K100RS Style Black 1987 105K Km     ;BMW; K1 Black 1993 51K Km     ;BMW; K1100RS Red 1993 70k miles  ;BMW; K100 16V Black (ex ElectricMonk)  ;BMW;  K1100LT (Swiss) soon to be an RS
18Back to top Go down   Finally found it Empty Re: Finally found it on Fri Aug 09, 2019 4:35 pm
moriarti
moriarti
1 NO blocking of these orifices will disturb the Vortex  that is required to maintain Blinker/Flasher rhythm
2 By using OLD MAC product cost is reduced due to its high versticular/low evaporation qualities
Being a non domisil product it is suitable for all border crossings.Available at most  good Saddleries
drunken
19Back to top Go down   Finally found it Empty Re: Finally found it on Fri Aug 09, 2019 6:17 pm
The new acoustic indicators eliminate the need for blinker fluid thus reducing emissions.
Continuous high/low tone for braking rising in pitch according to amount of braking being used, intermittent low tone for right turn, intermittent double high tone for left turn.
Finally found it Bakedb10
20Back to top Go down   Finally found it Empty Re: Finally found it on Fri Aug 09, 2019 8:08 pm
Hi Olaf
Which funnel do you put the fluid into - the top or "bottom" one ?
21Back to top Go down   Finally found it Empty Re: Finally found it on Fri Aug 09, 2019 10:46 pm
The fluid must be placed in the flasher can. Olaf, the acoustic version can leave you rather deflated after some time, a real bummer for those for those on long rides in cold weather.The manufacturer of the product really trumpets his success with this version but I believe he is just blowing in the wind.
22Back to top Go down   Finally found it Empty Re: Finally found it on Fri Aug 09, 2019 10:56 pm
I feel so silly I checked all my blinker bulbs thinking that was where the fluid went. Now I'll go check the flasher unit for a refill. Where can I go buy one of those Audible flasher units from I think the dualtone units would improve my chances by turning left or right with sound. Or soundly turning left or right.
Would it really hurt my bike if the synthetic blinker fluid is put in the non dualtone flasher unit??
How do I get the dualtone units to face the front, I don't want mine facing behind.
23Back to top Go down   Finally found it Empty Re: Finally found it on Fri Aug 09, 2019 11:24 pm
You could always try riding backwards????
24Back to top Go down   Finally found it Empty Blinking Riser Lights on Sat Aug 10, 2019 12:16 am
JimK
JimK
Hi all.
Missed you guys. Been reading even though have sold my beloved 89 SE, and intend to get another K when able.
Very grateful for all the help given here, and this community.
Saw a msg from Dai...mentioning...at least some of these folks could say, "Goodbye", when ceasing to be on the the Forum.
Wish upon all and your families, the best.
Thanks.
Regards.
Jimk
'89 k100 rs se
25Back to top Go down   Finally found it Empty Re: Finally found it on Sat Aug 10, 2019 12:31 am
Crikey JimK that sounds a lot more complex than being sent off for a long weight at the store.
So did they not blink because of friction? There in lies the need for blinker fluid to help them blink. Perhaps if you are ever yarning with any of those Sargents you can offer the fluid to them.
26Back to top Go down   Finally found it Empty Re: Finally found it on Sat Aug 10, 2019 12:42 am
JimK
JimK
"So did they not blink because of friction? There in lies the need for blinker fluid to help them blink. Perhaps if you are ever yarning with any of those Sargents you can offer the fluid to them."
Thanks,
Sure will.
Need to get some of that stuff.
JimK
'89 k100 rs se
