1Back to top Go down   Rocker cover rubber washers  Empty Rocker cover rubber washers Sat Aug 17, 2019 11:05 pm
Hello all
Wanted to check the valve clearences on my 86 K100 and replace the old rubber washers
I was suprised to see that the rocker cover bolts have a shoulder between the head and thread
Do I need to cut the old rubber ones off because i cant pull them pass this shoulder and then will the new ones push on pass this shoulder ?
Before i stuff them
1986 K100 RS Motorsport
1988 K100 RS SE
1990 K1 known as Barn Find
#### K100 RS Project
2Back to top Go down   Rocker cover rubber washers  Empty Rubber washers Sun Aug 18, 2019 12:04 am
daveyson
daveyson
They should be able to roll over without damage, but if they are too old and brittle the odd one might break.
The shoulder is a good idea to prevent the rubber washer from being overtightend. Some BMW cars also have them.
 ~120,000 km
3Back to top Go down   Rocker cover rubber washers  Empty Re: Rocker cover rubber washers Sun Aug 18, 2019 7:12 am
yes Mathew , replace them all , once done the pressure to the cam cover and crank cover inner gaskets is restored
from memory 22 required
the usual suspects o/s are worth checking for price
good luck
4Back to top Go down   Rocker cover rubber washers  Empty Re: Rocker cover rubber washers Sun Aug 18, 2019 9:55 am
22 for the whole engine Charlie - 12 for the cam cover. I've just been out and counted the new set I bought because like Matt, I need to change all of the cambox rubber.
Matt: yes, the new ones will push over the shoulder. If you're worried about them catching, a smear of silicon grease is a great help. If you look at the shape of the bolt, it's designed to bottom out on the cam cap so that as Daveyson says, the pressure on the rubber is correct. There's a downside: do NOT overtighten the bolts once they bottom out because you WILL strip/shatter the cam cap threads. Screw in until they touch down and then one-eighth of a turn further. I think that equates to about eight ft/lbs but it's always done me as a rule of thumb.
5Back to top Go down   Rocker cover rubber washers  Empty Re: Rocker cover rubber washers Sun Aug 18, 2019 5:20 pm
The torque for the engine side cover bolts is 8 +/-1 Nm.  (5.9 ft-lbs, 71 in-lbs)
6Back to top Go down   Rocker cover rubber washers  Empty Re: Rocker cover rubber washers Sun Aug 18, 2019 6:13 pm
Matt I have new washers put aside for my 75 not enough for your 100 but if you get stuck give me a yell.
7Back to top Go down   Rocker cover rubber washers  Empty Re: Rocker cover rubber washers Mon Aug 19, 2019 3:01 am
I must be weak these thing are solid as a rock, even the Stanley blade dose not want to cut into them
hope that the new  ones are easier to push over the shoulder
1988 K100 RS SE
8Back to top Go down   Rocker cover rubber washers  Empty Re: Rocker cover rubber washers Mon Aug 19, 2019 3:06 am
Use the Force young Matt. Do or do not there is no try.
Regards Yogi.
9Back to top Go down   Rocker cover rubber washers  Empty Re: Rocker cover rubber washers Mon Aug 19, 2019 3:17 am
Try softening the rubber with a heat gun or hair dryer. Let it cool so you don't burn your fingers. I soaked a hardened fuel filler gasket with a 50/50 mix of Rubbing Alcohol and Oil of Wintergreen it however took a long time and once left it hardened back up.
10Back to top Go down   Rocker cover rubber washers  Empty Re: Rocker cover rubber washers Mon Aug 19, 2019 3:17 am
11Back to top Go down   Rocker cover rubber washers  Empty washers Mon Aug 19, 2019 3:19 am
daveyson
daveyson
Stick a blunt screw driver between and lever over the shoulder, doesn't matter if they break, you're renewing anyway.
 ~120,000 km
12Back to top Go down   Rocker cover rubber washers  Empty Re: Rocker cover rubber washers Mon Aug 19, 2019 3:25 am
Matthew-Brisbane wrote:I must be weak these thing are solid as a rock, even the Stanley blade dose not want to cut into them
a good big set of sidecutters  works mate .....ask me how I know ....and I know you either have them or can borrow them ....eh?
13Back to top Go down   Rocker cover rubber washers  Empty washers Mon Aug 19, 2019 3:25 am
daveyson
daveyson
New ones will be good, old ones have got brittle.
 ~120,000 km
