1Back to top Go down   Sticky Down Shift...Spline Lube Empty Sticky Down Shift...Spline Lube Mon Sep 02, 2019 3:10 pm
tjh1985
tjh1985
I’m going to BMW Mechanic school over at Duck’s place! Had a sticky down shift which Duck correctly diagnosed as a dry spline. Took us about 2 hours to get to the transmission and spline which was dryer than the desert. 60 seconds to apply some spline lube now about 2 hours to put it all back together. Good times hanging with Duck though and learning s TON!
http://www.thomashurst.com
2Back to top Go down   Sticky Down Shift...Spline Lube Empty Re: Sticky Down Shift...Spline Lube Mon Sep 02, 2019 7:40 pm
This forum comes in as probably THE best one that I've ever signed up for in terms of help freely given, both virtually and in real life.
3Back to top Go down   Sticky Down Shift...Spline Lube Empty Re: Sticky Down Shift...Spline Lube Mon Sep 02, 2019 9:25 pm
caveman
caveman
tjh1985 and Duck,
Sounds like a good time, wish I was with you guys! I sure enjoyed my visit earlier this year.
4Back to top Go down   Sticky Down Shift...Spline Lube Empty Re: Sticky Down Shift...Spline Lube Tue Sep 03, 2019 8:47 am
Hear here Dai. No forum like this one.
I've had that sticky down shift and the spline lube helped improve it but it never went completely
Sticky Down Shift...Spline Lube Ir-log1188....May contain nuts!Sticky Down Shift...Spline Lube Ir-log11
K75RTP - 1994
5Back to top Go down   Sticky Down Shift...Spline Lube Empty Re: Sticky Down Shift...Spline Lube Tue Sep 03, 2019 1:21 pm
88 wrote:Hear here Dai. No forum like this one.
Use synthetic 75-140 gear oil and add half of a 50 gram tube of this:
Sticky Down Shift...Spline Lube 31ijmc0nmSL
