1Back to top Go down   Horn stuck on?? Empty Horn stuck on?? on Mon Sep 02, 2019 2:17 pm
giltgy
giltgy
When I initially powered up my bike(85 K100RT) the horn started
to blow until I unplugged at the horns. Does anyone know what could
be the cause of this. I have disassembled the switch assembly on the
left grip, and cannot see any obvious cause. Is it possible that the relay
is stuck on? The bike sat for many years(23?) before I got it and began to
get it roadworthy once again.
Thank you,
Guil
2Back to top Go down   Horn stuck on?? Empty Re: Horn stuck on?? on Mon Sep 02, 2019 2:42 pm
volador
volador
Hit the horn firmly with a blunt instrument to unstuck it
Good Luck with your moto
3Back to top Go down   Horn stuck on?? Empty Re: Horn stuck on?? on Mon Sep 02, 2019 2:55 pm
chris846
chris846
Maybe it's like when you bring an Egyptian mummy back from the dead - they're sort of fixated on whatever bad things happened to them all those years ago and they end up running round causing mayhem trying to deal with it, and making lots of noise.
Maybe your K100 had a bad experience before it was laid up, something scary, the horn was sounded?
Here's a picture of what I mean:
Horn stuck on?? Mummy10
The Longest Lunch
4Back to top Go down   Horn stuck on?? Empty Re: Horn stuck on?? on Mon Sep 02, 2019 3:04 pm
volador
volador
I felt the same way this morning!
5Back to top Go down   Horn stuck on?? Empty Re: Horn stuck on?? on Mon Sep 02, 2019 4:53 pm
Fix it soon; that mummy-wrap can chafe. Whack the relay, clean the handlebar switch.
1995 K75 73,000 miles
Horn stuck on?? Usa-lo10
6Back to top Go down   Horn stuck on?? Empty Re: Horn stuck on?? on Mon Sep 02, 2019 7:37 pm
It probably is the horn relay. You'll need to remove the fuel tank to get at the relay box - see this thread for ABS bikes:
http://www.k100-forum.com/t10767-relay-identification
and this thread for non-ABS bikes (you don't say what you have - '85 was a changeover year):
http://www.k100-forum.com/t869-testing-temperature-switching-relay
As for the children up there... Horn stuck on?? 167893
7Back to top Go down   Horn stuck on?? Empty Re: Horn stuck on?? on Tue Sep 03, 2019 11:32 am
K100RT. They didn't get ABS at all. DAMHIK
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
8Back to top Go down   Horn stuck on?? Empty Re: Horn stuck on?? on Tue Sep 03, 2019 12:50 pm
volador
volador
1: Motronic
2: Fan
3: Horn
4: Fuel pump
5: Load shed
Relays are all the same/interchangeable
9Back to top Go down   Horn stuck on?? Empty Re: Horn stuck on?? on Tue Sep 03, 2019 1:02 pm
Horn stuck on?? Relayb1
