1Back to top Go down   89 K100  Starter relay Empty 89 K100 Starter relay Mon Sep 09, 2019 4:55 pm
bobwhite_ok
bobwhite_ok
Anybody got one?
Bob
2Back to top Go down   89 K100  Starter relay Empty Re: 89 K100 Starter relay Mon Sep 09, 2019 5:50 pm
First thing you should try is whacking the right rear corner of the relay box (where the starter relay lives) with a crescent wrench or something.  Sometimes that'll unstick a stuck starter relay.
3Back to top Go down   89 K100  Starter relay Empty Re: 89 K100 Starter relay Mon Sep 09, 2019 9:34 pm
bobwhite_ok
bobwhite_ok
I tried that but to no avail.
I found one on Ebay for $40.
How do you get access to the relay box? Lift the tank?
Bob
4Back to top Go down   89 K100  Starter relay Empty Re: 89 K100 Starter relay Mon Sep 09, 2019 10:25 pm
Yes. lift the rear of the tank.
I strongly recommend that you disconnect the battery ground before messing with the starter relay.  One of the leads to it is hardwired to the battery and can be shorted if you're not careful.
