1Back to top Go down   TopBox swap Empty TopBox swap on Tue Sep 10, 2019 3:01 pm
Davep
Davep
Hi All
Just a quick question, will the standard top box from a LT/RT fit the RS? I assume it's the same bracket on all of the K's (I've looked through as many pic's as possible but can't see a difference).
To be exact will this fit my RS?
TopBox swap S-l1600
Many Thanks
Dave
TopBox swap Eu-log10 BMW K100RS 1983 (Main ride)
                      Suzuki GSX 750 ET 1979 (Needs work)
                      Kawasaki Zephyr 750 1992 (Needs hiding)
2Back to top Go down   TopBox swap Empty Re: TopBox swap on Tue Sep 10, 2019 3:30 pm
3Back to top Go down   TopBox swap Empty Re: TopBox swap on Tue Sep 10, 2019 4:41 pm
Have you the plate to go with it? The racks are all the same.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
4Back to top Go down   TopBox swap Empty Re: TopBox swap on Sat Sep 14, 2019 3:31 pm
Davep
Davep
Cheers for the advice guys.
So I have bought a new top box (different one to picture) and it has the plate with it, I have reinstalled the original rack that came with the bike (I had a Givi rack and box attached), So my plan is to ride up (100 miles) and fit the box there and ride home, just want to make sure I'm not going all the way up there to find I need something else to fit it.
I'm assuming that the plate fits under the rack and connects to the box through it. Or am I making this simpler than it is?
Cheers All
Dave
5Back to top Go down   TopBox swap Empty Re: TopBox swap on Sat Sep 14, 2019 3:34 pm
@Davep wrote:I'm assuming that the plate fits under the rack and connects to the box through it. Or am I making this simpler than it is?
If you have the attachment pin with its ring and washers, you should be good to go.
1995 K75 73,000 miles
TopBox swap Usa-lo10
6Back to top Go down   TopBox swap Empty Re: TopBox swap on Sat Sep 14, 2019 3:37 pm
If you have the case, plate and rack then you can fit the box to the rack off-bike to pre-test the fit.
