1Back to top Go down   Alternator  Empty Alternator Sat Sep 14, 2019 5:16 am
long way from home
long way from home
2 quick question -
1) does the plug on the back simply pull off, or is there a hidden clip, I don't want to break it.
2) Is there an easy way to check the output, mine is not charging the battery, and ignition lamp on dash stays on, even when reved
2Back to top Go down   Alternator  Empty Re: Alternator Sat Sep 14, 2019 6:14 am
1) Pull on it while shaking it back and forth. No secret clip.
2) The lamp in the cluster tells you it's not working.
3Back to top Go down   Alternator  Empty Re: Alternator Sat Sep 14, 2019 7:50 am
long way from home
long way from home
duck, thanks it pulled off, I'll now get it checked out, auto electrician..
Andrew
4Back to top Go down   Alternator  Empty Re: Alternator Sat Sep 14, 2019 8:05 am
Probably just the regulator. They're only around £20 in the UK.
5Back to top Go down   Alternator  Empty Re: Alternator Sat Sep 14, 2019 9:51 am
+1 on the regulator.  I had to replace mine because it wasn't charging and barely keeping the bike's voltage high enough to keep the engine running.  The brushes do wear out as well.
6Back to top Go down   Alternator  Empty Re: Alternator Mon Sep 16, 2019 6:02 am
I had same issue on one K and regulator swap cured it As said a cheap part.
