1Back to top Go down   WTB: Broken K100 Transmission Gear Switch Empty WTB: Broken K100 Transmission Gear Switch on Wed Oct 16, 2019 1:07 am
Tjsunny2
Tjsunny2
Hi All,
I found that my TGPI switch has a melted spring which is preventing my neutral light from turning on. Does anyone have a broken TGPI switch with at least one good contact spring? Please see below for pictures of one of the good springs.
Thanks,
TJ
WTB: Broken K100 Transmission Gear Switch Img_0011
WTB: Broken K100 Transmission Gear Switch Img_0010
Early 1985 K100 RS being restored into a K100 Standard
I've pulled replacement springs out of lighters, pens, old switches and electrical gizmos over the years.
Tjsunny2
Tjsunny2
Good idea! Let me see what I've got
Tjsunny2
Tjsunny2
Bump^^ If anyone has one of these broken switches, I'm still interested. I haven't been able to find a spring small enough for this application.
It looks very close to a BIC lighter spring in size. If I had one to pull apart I'd check.
gorio
gorio
@MartinW wrote:It looks very close to a BIC lighter spring in size. If I had one to pull apart I'd check.
Bic's have a good quality spring too. It is used the keep the flint against the striker wheel if you were wondering where the spring in a lighter is.
Also you maybe able to find an assortment of spring to buy.
https://www.ebay.ca/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR2.TRC1.A0.H0.Xsmall+compression+springs.TRS0&_nkw=small+compression+springs&_sacat=0
1992 k100rs for fun
2006 r1200rt for heavy lifting
